FWD blowing fuses
/ FWD blowing fuses #1
tulenutn2o
Platinum Member
Central,Iowa
Kioti DK45S
2009 Kioti DK45S FWD keeps blowing fuses. Have not had a chance to dive deeper yet.
/ FWD blowing fuses
So pto and fwd both not working now. I fixed the fuel leak issue, turned out to be fuel return off injectors. FWD still blowing fuses instantly. I suspect pto safety switch in dash for pto. I hope to find something simple. Anybody else have these issues? Also, the hour meter stopped working.
/ FWD blowing fuses
Update: pto and hour meter fixed. Completely disassemble dash and switches. Cleaned all contacts and all good now on that front. I am glad the switches were simple tab assembled versus plastic welded/sealed/unserviceable type. Now onto the fwd. I am hoping for a pinched wire somewhere. That wire tracing should be fun.
/ FWD blowing fuses #4
It's only a tractor so prety minimal pannels to move and you have acess to nearly every wire on the machine.
/ FWD blowing fuses #5
On my 2911 DK 45 cab, The pto and 4x4 on the kioti tractors , if they use the switch instead of a lever, have a relay under steering wheel plastic cover. You also need to test the output on the switch. I recall a few other people that had switches fail. Theres also a 4x4 solenoid under the tractor, but i hope thats not the isdue, cause thats very expensive.
The pto and 4x4 use the same fuse, so if pto is working, its not the fuse. There is a wire running to the 4x4 solenoid which may have been damaged.
/ FWD blowing fuses #6
/ FWD blowing fuses #7
For the life of me, i cant find where the 4x4 solenoid is even located. The pto solenoid is on the transmission top, but not sure where the other one is. The only thing 8 find is a crappy picture, but not very detailed. Part 37 is the solenoid
/ FWD blowing fuses
Your point is valid but between the years of grease, grime, and general crud, it can be a challenge….and then there is the fact that it was in the hot sun with 70+% humidity. I did fix the fwd, it too was switch related. All working well now except I think I reinstalled a screw or two, into the dash circuit board in the wrong position. My temp and fuel gauge not working. They worked prior.
/ FWD blowing fuses
The circuit board uses a few brass screws that I got out of position, apparently. That will be a few days or so away as we are entering a brutal hot, humid, stretch of weather. Hibernation is in order.:)
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
PALLET OF HAND PUMPS (A63745)
PALLET OF HAND...
(INOP) 1990 PETERBILT T/A DAY CAB ROAD TRACTOR (A63745)
(INOP) 1990...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
(2) 620/70R42 TIRES (A63745)
(2) 620/70R42...
