Fuse box plug layout
/ Fuse box plug layout #1
Thomas G
Jinma 284
Seeking the pin layout on the fuse box for 284 le jinma
looking to add the battery waring light and wire harness doe not have wire 41 and have empty slots forwires
Thanks
Thomas:tractor:
/ Fuse box plug layout #2
Info you seek is in the wiring diagram in the Jinma operations & maintenance manual. It's one of a set of 4 (manuals) that you should have gotten with the tractor. There's a second wiring diagram in the tractor parts manual, but it's not as detailed.
//greg//
I check with the books I received with my Tractor and all the have is a wiring drawing with does not go with my tractor it is not for a instrument cluster .
I found a good wiring drawing on this site for a tractor with instrument cluster ,but when the wire is not there you can not find out what pin it in the plug . the wires on the fuse box side are not number so that why i an seeking a plug pin layout
thanks
/ Fuse box plug layout #4
Thomas,
Not sure that I understand what you are looking for, but see if this helps.
RonJ
yes this is what I am seeking I see where wire 41 should go .
drawing is good did you make it up yourself? if not where did you get it would like to get all plug details if I can find them
Thanks you
Thomas
/ Fuse box plug layout #6
Yes, I made it myself. When there were occasional problems, I went through the same re-learning experience each time. Decided that was kind of dumb of me, so took the time to record the wiring.
RonJ
Good Job
the Jinma are a great tractor but the manuals need a lot of work .
My tractor a Le and the book I have is for a older model
so I am always looking for any info I can find to save
Thank for the info
Thomas
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2006 CASE 430 SKID STEER (A65053)
2006 CASE 430 SKID...
2025 Miscellaneous Mini Excavator Attachments (A64553)
2025 Miscellaneous...
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
2022 EZ-GO ELITE...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
