Fuse box location on MF 231 (not231S)
   / Fuse box location on MF 231 (not231S)
He Travis_R
Thanks for the pictures. I did find the fusebox. A couple of the fuses were blown, replaced those, now the lights work...an signals. I think one of the pic's shows maybe the in-line fuses, those are the one's I really need to find and check.With the weather warming up I can get out and do some more fiddling with the tractor.
   / Fuse box location on MF 231 (not231S) #22
He Travis_R Thanks for the pictures. I did find the fusebox. A couple of the fuses were blown, replaced those, now the lights work...an signals. I think one of the pic's shows maybe the in-line fuses, those are the one's I really need to find and check.With the weather warming up I can get out and do some more fiddling with the tractor.
Yes, one of the pictures shows the inline fuses. According to the operator's manual, one fuse is the rear work light and auxiliary power socket (blue wire) 12 Amp.
The other fuse is the horn (grey wire) 10 Amp.
I had to replace a couple fuses to get some of my lights working also. Replaced them a few years ago and never had a problem since.
Where did u get your fuses? I ordered mine from a Massey Ferguson dealer.
   / Fuse box location on MF 231 (not231S) #23
Here are some more pictures and info you may be interested in...
Travis_R ..I got my fuses from the MF dealer also.
Tomorrow, Sunday me and my brother are going to trace all wires to find the inline fuses.
Travis I forgot to mention that the MF dealer says he is going to scrounge around for me a owners manual.
Hope he can make that happen.
   / Fuse box location on MF 231 (not231S) #26
Did you ever figure out anything on the alternator not charging issue?
   / Fuse box location on MF 231 (not231S) #27
I'm not having any battery/starting issues with my 231, but the charging indicator light on the dash panel keeps blinking at engine idle. It's been doing this a long time now but has never gave me any starting issue. This is AFTER I start it up and give it a little throttle to make the light go completely out. After the light goes out and I bring the engine right back to idle, the red charging light tends to blink a lot. ...But I notice when I have the lights on or 'using' something with the electrical system, the light doesn't seem to blink. I wonder if a loose alternator belt could be the problem? I know it's a little loose.
For anyone wanting to know for future reference (but mainly for my forgetful mind to look back on), I found out today why the charging light kept blinking.. The only problem was the alternator/fan belt was loose!! I knew it needed tightening, but I didn't realize it was as loose as it was.
Tightened it up and no more blinking!
2012 Freightliner Cascadia 113 Semi (A50514)
2012 Freightliner...
15 FT Trailer (A50322)
2016 Dodge Caravan (A50324)
2016 Dodge Caravan...
Land Honor Quick Attach Rock Bucket (A50514)
Land Honor Quick...
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
