Fuel what do you use
/ Fuel what do you use #43
My local PetroCanada sells dyed #2 for $0.15 cheaper. If you buy less than 40L you don't have to have farm status or other tax exempt number, so I fill a jerrycan regularly. Sometimes I have a little left after filling my L245DT and it goes into the truck...
/ Fuel what do you use #44
......................... - I want to ask them how much they dispense per week, per month. The highway diesel I get at the Texaco station works just fine - costs about 35 cents more per gallon and I know they dispense hundreds of gallons per day....................
Not a problem - I fill up few 55 gallon plastic fuel drums with off-road Diesel at the same station where our local school buses fill up!
Small amount of biocide added makes sure it stores for many years in the barn.
/ Fuel what do you use #45
Here in Quebec only stationary generators* may use 'off road', all other applications must use taxed road fuel.
A friend who owns a B21 found out the hard way as the fuel police sampled and found heating oil in 2 of his tractors.
*and that is probably because the power company (also Quebec provincial owned) generates hydro power in many remote locations.
I find it amazing that there are people in your country going out policing peoples' fuel tanks. IMO, this is a gov't that has run amok.
/ Fuel what do you use #46
They do it here in the USA too. They dip the tanks of road going trucks to see if they come out pink. If they do, it sucks to be you.
At least here in the US, the extra taxes in road fuel vs dyed off-road fuel goes to maintaining the roads. Personally I dont mind paying for paved roads as it beats dirt roads.
/ Fuel what do you use #47
What bothers me is that tractors can't use off road diesel, seems a little ridiculous. Road going vehicles I don't have a problem with checking them, especially in problem areas where farmers and logging trucks have a tendency to try and skirt the road tax.
/ Fuel what do you use #48
Agreed. If the primary use of the tractor or truck is off-road then let them be. Crossing a road to another field should be no issue as well.
/ Fuel what do you use #49
Yeah, crossing a road that was built on the farmers land...
/ Fuel what do you use #50
Just to clarify, they don't restrict tractors from using off road fuel here, in Va at least, is that a all of Canada thing or just a providence thing?
/ Fuel what do you use #51
Just to clarify, they don't restrict tractors from using off road fuel here, in Va at least,..............
You mean as long as you drive the tractor on private land and stay off public (tax funded) roads?
/ Fuel what do you use #52
You mean as long as you drive the tractor on private land and stay off public roads?
No, they can travel between fields etc. on public roads. Stupid to make a tractor that spends maybe a couple % of its time on public roads pay road tax on all its fuel.
I live in an area that is still fairly agriculture, at least for the time being.........
/ Fuel what do you use #53
I am not aware of any place in the US that requires highway diesel to be used in a tractor that is primarily used for non-highway purposes.
I have not heard of anyone having their fuel tank dipped on a tractor, trucks yes. However I am not sure how the regulations apply to ag or farm
licensed trucks. Also I expect that every state is different.
Our tractors get lots of road miles traveling from farm to field and field to farm, yesterday I had 8 round trips using the road from various fields
hauling round bales in to be wrapped.
/ Fuel what do you use #54
Around here farm registered road vehicles are still required to run road tax fuel, unless they never leave the property.
Lou I'm sure there are exceptions but overall how hrs out of a tractor's total hrs are spent on the road? Based on what I see around here it's pretty low.
/ Fuel what do you use #55
Around here it varies quite a bit,
the smaller family sized farms that still chop (silage hay and corn) into wagons and not trucks such as the large operations do.
As an example for haylage,
going to mow is road to the field a few miles, several hours in the field and then back to the farm,
tedding, raking is the same,
then chopping, one tractor on the chopper to the field and then in the field chopping, then
2 or 3 tractors and people hauling and unloading, these tractors will spend the majority of the day roading
back and forth, more road time then in the field and unloading.
Then the silo blower or bagger tractor is sitting and working all day with no road time.
In this area the roads are commonly used to get to and from fields and even from one field to the next.
All in all it's hard to say how many hours are field and how many are road, but quite a few road hours in the course of a growing and harvest season.
/ Fuel what do you use #56
Just a Canada thing I believe. If I recall the only things that can run un-taxed (dyed I'd assume) fuel up there is generators.
I run my tractor down the dirt roads a lot (often even with my LPGS down, intentionally). Only do a few miles tops occasionally on paved roads & have no problems here in Colorado.
I'm pretty sure most or all of the USA only cares about dyed off-road diesel in the tanks of licensed road going vehicles. Tractors aren't licensed so not relevant to the issue.
/ Fuel what do you use #57
Ye I agree, and it looks like the bottom line is:
As long as you stay on private land there are no restrictions for off road Diesel fuel usage in most states.
The moment you enter public road there are restrictions in most states / provinces and anyone doing so should learn the local restrictions or else .....
:banghead:
/ Fuel what do you use #58
Fallon said: I'm pretty sure most or all of the USA only cares about dyed off-road diesel in the tanks of licensed road going vehicles. Tractors aren't licensed so not relevant to the issue.
Exactly, 100% correct. Has to be ALL states. I am amazed that there is so much confusion over this grossly simple subject. It has only to do with road use taxes. Somebody running off-road dyed fuel in his truck, car or 18 wheeler is likely to get fined for it. Diesel burning cars/truck get spot checked by the state every once in a while here in MD. Also in WV and I'm betting in every state in the union.
Arto said: As long as you stay on private land there are no restrictions for off road Diesel fuel usage in most states.
The idea that "the moment you enter public road..." is a whole lot more draconian than any actual enforcement. Show me one case in any state where the operator of a farm tractor has been fined for running off-road (untaxed) fuel. That's not happening.
I take folk's word for it that the rules in Canada are apparently different. Strange but could be.
/ Fuel what do you use #59
While most provinces have no shortage of govt, outside of Quebec, I'm not aware of Ag tractors being targeted re. on-road fuel.
Rgds, D.
/ Fuel what do you use #60
diesel whether its off road or on road is not #2 fuel oil. #2 is not ultra low sulfur. It will be sometime this fall as all will be low sulfur.
2006 Flori Off Road Dump Truck DF40 (A65579)
2006 Flori Off...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
INOP/NON-RUNNING 2005 Kenworth W900 Sleeper Truck, VIN # 1XKWDB9X55J074790 (A65563)
INOP/NON-RUNNING...
