Fuel what do you use
/ Fuel what do you use #21
After they changed to low sulfur diesel I had to rebuild my fuel system on my 99 F350, The seals in the fuel bowl melted ....
I am surprised older tractors didn't have the same problems.
/ Fuel what do you use #22
That's different, because the sulfur is a lubricant, and with lowering the sulfur you get more wear. Melting would make me think along the lines if someone mixed kerosene with it
/ Fuel what do you use #23
Is #1 home heating oil ULSD? I use the Power Service additives for lubricity. 20 miles to a service station.
No, #2 heating oil is ULSD (in many areas).
Issue i n TN and KY is the sulfur content. If I go to TN (10 miles from the line) I can get off road ULSD, LSD and HSD. If I go to KY I can get only LSD and who knows. I say who knows because there is no label on the pump, and if I ask they don't know.
So in all my old stuff, it can burn what ever, but the JD tractor and Kubota RTV need at least LSD and now the F3990 needs ULSD. I have even found LSD at a station pump for road use to this day. Folks pulling their new truck in an filling up that don't notice the label will mess there truck up
In the continental US, I am 99% certain that it is ULSD, no matter what the sticker on pump says.
LSD and HSD were both completely eliminated as of 2014:
https://en.wikipedia.org/wiki/Ultra-low-sulfur_diesel said:
There are exemptions for small refiners of non-road, locomotive and marine diesel fuel that allow for 500 ppm diesel to remain in the system until 2014. After December 1, 2014 all highway, non-road, locomotive and marine diesel fuel produced and imported will be ULSD.
Aaron Z
/ Fuel what do you use #24
Good thing there is a 1% variance otherwise I might ask for some proof
/ Fuel what do you use #25
I just want to do what's best for my Tier IV tractor. To much money involved to scrimp on the wrong fuel.
/ Fuel what do you use #26
Where do you buy off road diesel? Gas stations around me only sell ultra low sulfur diesel with road taxes. I doubt my heating oil dealer would let me fill up my 5 gallon gas cans with #2 heating oil!
/ Fuel what do you use #27
I am not trying to hijack this thread, but the fuel formulations can and will affect all equipment. The rebuild kits are available through numerous sources for the 7.3 Powerstrokes due to the high failure rates caused by the reformulated fuels. I also had a 53 Oliver Super 55 that I would have to add "Lead Substitute " to the fuel to keep it running right.
If you look at Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
"Although the fuel manufacturers have not claimed responsibility, the number of reported fuel leaks on the 7.3's can not reasonably be accounted to coincidence since the introduction of ULSD. What I have found is that some of the chemical additives in ULSD are separating the PTFE coatings that Ford uses on their fuel and oil seals from the o-rings themselves.
When the coatings separates two things occur:
The PTFE coating does not separate evenly, leaving gaps that fuel can travel past the sealing surface causing the "leak" to appear, usually on top of the engine..
Most all of the factory o-rings are made of Buna-N which has a greater percentage of swell and the least amount of resistance to fuel permeation than other elastomers offered in the industry, namely Vitonョ. Fuel permeation and swell causes the elastomer to become soft and unable to seal the fuel pressures found in the 7.3 fuel injection system."
/ Fuel what do you use #28
Have been buying on road motor fuel(and paying the tax). When needed, I've added #1 Home Heating oil with some additives for lubricity. I can never remember to call the fuel Jobber to get a definitive answer on if it is ULSD.
/ Fuel what do you use #29
I use heating oil in my '91 7.3l plow truck also. It is never on the highway and is unregistered. No problems in the past 20 years and I've even changed the oil once.
/ Fuel what do you use #30
#1 fuel oil is kerosene
#1 diesel fuel is kerosene
#2 home heating oil is #2 diesel
depending on your area winter blend will usually be #2 with additives until the temp get too low at which time #1 is blended in till at extremely low temps #1 is the recommended fuel.
Some engines will call for winter fuel as high as 50 F
/ Fuel what do you use #31
Here in Quebec only stationary generators* may use 'off road', all other applications must use taxed road fuel.
A friend who owns a B21 found out the hard way as the fuel police sampled and found heating oil in 2 of his tractors.
*and that is probably because the power company (also Quebec provincial owned) generates hydro power in many remote locations.
/ Fuel what do you use #32
Guess I'd better be calling the fuel man before I mess something up. Thanks for that info. No telling what they use up here.
/ Fuel what do you use #33
That is really Lame. Tractors are not "on road" vehicles and are not the ones wearing out the highways. I'd find a friend with some dye. When the dyed fuel first came out, it wreaked havoc on out boiler burner nozzles. Made quite the mess. No dyes in the fuels here now.
/ Fuel what do you use #34
We get ours from the same company we get our heating oil from. He fills up the heating oil tank, then fills up the tractor tank.
Aaron Z
/ Fuel what do you use #35
Exactly why I run road diesel with 2 ounces of power service and 4 ounces of marvel mystery oil per each five gallons. One injector can cost $100.00 dollars, plus aggravation of installing.
/ Fuel what do you use #36
There is no Ag exemption in PQ ? Wow, that is lame. I'm also surprised that construction equipment isn't exempt.
Back to OP - dye is just a tax issue here (Canada) too - your chance of getting anything other than ULSD at a retail pump here is basically zero.
Fuel lubrication can be an issue, but there are things (rural lore) that you do not want to be putting into a modern tractor as additives - ex. ATF.
Rgds, D.
/ Fuel what do you use #37
Found this and seems all diesel is ULSD now days, whether it had dye or not.
Ultra-low-sulfur diesel fuel was proposed by EPA as a new standard for the sulfur content in on-road diesel fuel sold in the United States since October 15, 2006, except for rural Alaska which transferred in 2010. California has required it since September 1, 2006. This new regulation applies to all diesel fuel, diesel fuel additives and distillate fuels blended with diesel for on-road use, such as kerosene, however, it does not yet apply to railroad locomotives, marine, or off-road uses. Since December 1, 2010, all highway diesel fuel have been ULSD. Non-road diesel engine fuel was required to move to 500 ppm sulfur in 2007, and further to ULSD in 2010. Railroad locomotive and marine diesel fuel also moved to 500 ppm sulfur in 2007, and will change to ULSD in 2012. There are exemptions for small refiners of non-road, locomotive and marine diesel fuel that allow for 500 ppm diesel to remain in the system until 2014. After December 1, 2014 all highway, non-road, locomotive and marine diesel fuel produced and imported will be ULSD.
/ Fuel what do you use #38
Cheaper, no tax on it. I have one station that sells both.
/ Fuel what do you use #39
Do you have any problem in the winter with the heating oil? I have an oil tank with 170 gallons in it I need to get rid of as I am switching my dual fuel wood boiler to propane instead of oil. I'm thinking of pumping it out and using it in my Kubota L2250 and my Massey G2300. Do you put additives in it?
/ Fuel what do you use #40
OK - my take on this. About two years ago - one of our local service stations became a Chevron station and they have "red diesel". Before I will use any of their diesel - I want to ask them how much they dispense per week, per month. The highway diesel I get at the Texaco station works just fine - costs about 35 cents more per gallon and I know they dispense hundreds of gallons per day. If I were burning large volumes - then I would seriously consider "red diesel" - - but then, like all the other farmers in our area - I would have a storage & dispensing setup and have the local distributor delivering it.
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
Ford 550 Backhoe (A65579)
Ford 550 Backhoe...
2007 Top Brand Deck Over Trailer, 18'+3' Dovetail (A62679)
2007 Top Brand...
KILLBROS GRAVITY FLOW WAGON (A64277)
KILLBROS GRAVITY...
2022 EZ-GO ELITE...
