Fuel tank
/ Fuel tank #1
McNair333
Ford 3000
Hi I'm new to the group and I'm working on a free Ford 3000 diesel. It's not locked up so that's a plus. Was told it was having issues with getting fuel. So I'm going to start with cleaning the lines then go from there. The question I have is are all of the Ford 3000 fuel tanks the same? They all look alike but have different part numbers. I'm guessing they have slight differences but I don't know what from looking at them. The tank that's on it has severe rust and I'm pretty sure holes along with it.
/ Fuel tank #2
Check for holes first. If no holes they make coatings you put in the tank and slosh around. Cleaning can be done with degreaser and a small section of chain.
/ Fuel tank
I was going to do that but when I looked 1 corner is completely rusted through. Pretty big spot about the size of a my fist.
/ Fuel tank #4
Yea sealant isn't going to cover a fist sized hole.
You'd need to find the serial number and then find which tank goes with it.
Or go with one like this: Ford 3000 Fuel Tank - C5NN9002AC
and deal with the minor differences. The folks at yesterdaystractors can probably tell you if it will fit your tractor.
/ Fuel tank #5
One thing I'd do is add a fuel polishing unit to the fuel line and replace all the fuel lines as a matter of consequence. Sounds to me like a new tank is in order anyway.
/ Fuel tank
Thank for the replies.
STORAGE FEES (A59914)
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
NEW Wolverine 66" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 66"...
2014 FREIGHTLINER CASCADIA,TANDEM AXLE 6X4 SLEEPER TRACTOR (A59914)
2014 FREIGHTLINER...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
