Fuel tank
/ Fuel tank #1
McNair333
Ford 3000
Hi I'm new to the group and I'm working on a free Ford 3000 diesel. It's not locked up so that's a plus. Was told it was having issues with getting fuel. So I'm going to start with cleaning the lines then go from there. The question I have is are all of the Ford 3000 fuel tanks the same? They all look alike but have different part numbers. I'm guessing they have slight differences but I don't know what from looking at them. The tank that's on it has severe rust and I'm pretty sure holes along with it.
/ Fuel tank #2
Check for holes first. If no holes they make coatings you put in the tank and slosh around. Cleaning can be done with degreaser and a small section of chain.
/ Fuel tank
I was going to do that but when I looked 1 corner is completely rusted through. Pretty big spot about the size of a my fist.
/ Fuel tank #4
Yea sealant isn't going to cover a fist sized hole.
You'd need to find the serial number and then find which tank goes with it.
Or go with one like this: Ford 3000 Fuel Tank - C5NN9002AC
and deal with the minor differences. The folks at yesterdaystractors can probably tell you if it will fit your tractor.
/ Fuel tank #5
One thing I'd do is add a fuel polishing unit to the fuel line and replace all the fuel lines as a matter of consequence. Sounds to me like a new tank is in order anyway.
/ Fuel tank
Thank for the replies.
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
2017 Hyundai 53' Dry Van (A62613)
2017 Hyundai 53'...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
