Oil & Fuel Fuel tank vacuum
/ Fuel tank vacuum #1
jbitting
Clover, SC
YM1500
I have a YM1500. Plastic fuel tank, fuel line out the bottom. There is another (small) line going into the tank by the cap. I thought it was a vent until I saw it was coming from the injectors... what is this little line for?... meanwhile, my fuel tank is pulling a vacuum and trying to crush itself.
1. should the small line be coming from the injectors and what is it?
2. how do I get around the tank vacuum?
I'm sure one of the Yanmar vets has seen this before.
any help appreciated.
Thanks,
Jake
/ Fuel tank vacuum #3
I believe he is speaking of what the manual calls a bleed off line, that runs from the injectors to the tank.
/ Fuel tank vacuum #4
The line is for unused fuel returned to the tank. I had a YM1401 do the same thing with the tank. I had put the wrong cap on it. The cap must have a vent. I had actually put a new gasket on the cap and it was too soft and closed the vent notch in the cap threads.
/ Fuel tank vacuum #5
Jake,
My YM1700 did that a few times if I tightened the cap too tight. If I put it on enough to not vibrate loose, all was well with the tank.
Hope this helps
/ Fuel tank vacuum
Roger that fellas...
Thanks for the replies...
will check the cap/gasket and make sure all is well with the vent notch.
I have been known to overtighten a cap now and then too <grin>
appreciate the replies.
Thnx much,
Jake
/ Fuel tank vacuum #7
if you check and can't find vent run engine with fuel cap slightly loose the pumps on the engine draws a vacum just like old fuel pumps on gas so if tank ain't vented it will pull vacum on it's self..
Ford 5610 (A64119)
Ford 5610 (A64119)
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
IRanch High-End Tricycle (A64119)
IRanch High-End...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A64279)
2020 CATERPILLAR...
