Fuel storage
/ Fuel storage #1
remington270
Alabama
Kubota M7040, Kubota B2710
I am considering storing diesel fuel in a 55 gallon drum (metal or plastic). I would then use a had crank to pump it into the tractor. I'm sure some of you guys have done this. How did it work? What's the best way to get the container to/ from the gas station?
/ Fuel storage #3
You may actually be able to buy the fuel in a drum, I haven't tried but I think I have heard that you can. Of course maybe that is just racing fuel or some specialty blend or something- not sure. Might be something to look into, may even save a penny or two.
/ Fuel storage #4
Like this.
Drum is always empty when ever it is put on or taken off the truck.
/ Fuel storage #5
This is exactly what I do. I remove the hand pump and just manually lift the drum into the pick up when it's empty. I have a drum lifting tool that I picked up at Harbor Freight that I use with a chain and a bucket hook on the FEL to remove the full drum. I do the same for our ranch gas. I keep it under cover in the machine shed. I've done this for about 7 years now and have not had any fuel contamination problems with either type of fuel.
/ Fuel storage #6
Since LBrown hasn't kicked back in yet -
The drum is always empty when ever it is put on or taken off the truck. He transfers it to "ground based" drums.
/ Fuel storage #7
I have heard if you use a plastic drum that the light shining through it will promote algae to grow. I would recommend a pump with a filter on it.
/ Fuel storage
That's a great idea. Never thought of doing that. The heavy weight of lifting a full drum is avoided!
/ Fuel storage #9
Have you ever considered checking out if you could get delivery? Obviously you want to get fuel for ag use (not road taxed). Delivery fees might be less overall cost and hastle than you are currently encountering.
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2024 Kubota SVL 75-3 (A64126)
2024 Kubota SVL...
Massey Ferguson 8200 Flex Grain Platform (A66285)
Massey Ferguson...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
1986 Trailmobile 40Ft F71T-6UJA Trailer (A64194)
1986 Trailmobile...
