Fuel Stabilizer Types - Suggestions for JD ZTR, X330?
   / Fuel Stabilizer Types - Suggestions for JD ZTR, X330? #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
I’m questioning whether I should add Fuel stabiizer to my ZTR and X330. Right now I store them in my pole barn - batteries and fuel still in them - for the winter. Thoughts? Should I add Stabilizer and use battery tenders? I do turn them over (as well as my B) weekly.
Thanks!
   / Fuel Stabilizer Types - Suggestions for JD ZTR, X330? #2
I have good luck using stabil on stored equipment. If starting you need to run them long enough to get good and warmed up to help remove any condensation build up in the oil. I disconnect the battery and charge once a month on vehicle like motorcycle that will not be used during the winter.
   / Fuel Stabilizer Types - Suggestions for JD ZTR, X330? #3
I've used Sta-Bil for many years now in both my gas and diesel lawn mowers and tractors. I just add it to every 5 gal fuel can and use it year-round. They work for me.
   / Fuel Stabilizer Types - Suggestions for JD ZTR, X330? #4
I always use Stabil in my small engines. I think it’s more important to use ethanol free gas for longer storage. If I keep the tanks full with Stabil treated ethanol free fuel I’ve never had a problem. My second choice is to run them dry.
   / Fuel Stabilizer Types - Suggestions for JD ZTR, X330? #5
Marine Stabil for me in all my gas engines in storage, make sure the fuel tank is full.
I wouldn't bother to turn them over biweekly.
I don't use a battery tender. A neighbor lost his garage to a fire started by a battery charger, fortunately it was a detached garage.
   / Fuel Stabilizer Types - Suggestions for JD ZTR, X330? #6
I don't have a problem when using ethanol-free gas just parking them all for the winter in a non-heated shed. Most, in my opinion, are just a "feel good" expense.
   / Fuel Stabilizer Types - Suggestions for JD ZTR, X330? #7
Fuel stabilizers do help and there is also truth to statement that non ethanol fuel stores better. The very best thing to be done is what you are doing. The most sure fire way to keep the fuel from oxidizing and deteriorating in the carburetor is to replace it. By running the engine, you are cycling fuel which is not oxidized through the carb. Remember that the carb bowl is vented. Also it is a relatively small amount of fuel, with a higher ratio of surface which is exposed to the atmosphere. A larger volume of fuel deteriorates much slower. Couple that with your tank vent being quite small and in the airbox, it lasts much longer. Another plus is you've replenished the charge in the battery and recycled the lubrication around the engine.
   / Fuel Stabilizer Types - Suggestions for JD ZTR, X330? #8
Thanks!
I do, most years. Never had a problem either way, but I figure it's probably better with than without, and it's not like the $12 bottle that treats 128 gallons is going to break the bank for the little I use each year.
I usually try to start adding it to my 5 gallon cans, prior to the final mowing or two of the season. Gets run thru my mower, walk-behind leaf blower, etc. I don't bother with it in-season.
My storage is similar to yours, unheated shed with a concrete floor. Dry, but drafty, which means everything gets soaked with condensation the first warm days in spring.
Sounds very similar here. I’ve never had issues in the past using Diesel and Gasoline treatments…. And I believe by running the engines that it helps everything stay consistent. I just figured that I’d check with some of the other folks here on whether this is still a good practice.
The good news is that it is. Thanks and Merry Christmas, all!
2002 CLEMENT END DUMP TRAILER (A52472)
2002 CLEMENT END...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
