Fuel shutoff solenoid
/ Fuel shutoff solenoid #1
trentd11
Madison, MS
John Deere 5325
I have a JD 5325 that has been blowing a 20 amp fuse. I discovered the cold sensor switch was the cause. Still won't start. Does the fuel shutoff solenoid have a fuse?
/ Fuel shutoff solenoid #2
After disconnecting the cold start advance at the injection pump and replacing the blown 20 amp fuse for the fuel shutoff solenoid, it should have started up. What volt meter did you get at the injection pump/fuel shutoff solenoid?
I haven't gotten a reading yet. Gonna go back up to the farm n a day or so to try to figure it out. Just trying to gather all info I can before I go.
/ Fuel shutoff solenoid #5
My 5303 will start with the CSA unplugged, it really dosen't get cold enough here to worry about it, i did replace the $42 piece of junk though.
Ronnie
/ Fuel shutoff solenoid #6
I have a 5325 and the repair manual on cd. The fuse blowing is one of the few problems I haven't had. Is this a straddle mount? 5 cylinder turbo? They have a control rod going to the unit injectors.
