Oil & Fuel Fuel shut off valve will not close.
   / Fuel shut off valve will not close. #1
JohnDeere4300
John Deere 4300
Today is the first problem I've had with the shut off valve, and it worked fine yesterday.
After using my tractor today i went to turn the fuel off and it WILL NOT turn.
I worked on it for over an hour & even sprayed some WD-40 on it but it won't close.
It fills tight & could break off if i really force it.
anyone have any suggestions?
   / Fuel shut off valve will not close. #2
Sounds like something internally stopping it up.
Drain tank and remove and clean valve. What ?, you thought this was going to be easy ?
If valve isn't removable, drain and try blowing backwards through valve with some compressed air. Heck, even a can of keyboard cleaner would work.
Well i am almost empty on fuel.
Yea i thought it would be easy:D
I'll check it out in the morning & spray everything i have on it.....I'll try the keyboard cleaner.
Have you had this happen before ?
   / Fuel shut off valve will not close. #4
I'm almost afraid to say I don't even shut off my fuel. So, no, not on this machine.
But, I had a valve similar on a motorcycle tank that froze stiff with that whitish buildup you get with alum valves/fittings.
A good cleaning and lots of lube and slowly working it back and forth got it working again.
Willl,
I got the shut off valve to work today.
I sprayed it down with "nut buster" and was able to work it back & forth without breaking it off.
   / Fuel shut off valve will not close. #6
Very cool.
Any idea what was hanging it up ?
Very cool.
No,
The day before it worked fine, and yesterday when i went to turn the fuel off it was so stiff that i couldn't turn it by hand, and i was afraid it would break off if i used channel-locks.
Just one of those :confused: days.
2014 VOLVO VNL DAYCAB (A58214)
2014 VOLVO VNL...
INDUSTRIAL PARTS WASHER W/ CONTROL PANEL (A52708)
INDUSTRIAL PARTS...
Kubota L3560 (A57148)
TAG Bucket Excavator Attachment (A55973)
TAG Bucket...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
TAKEUCHI TB235-2 EXCAVATOR (A52709)
TAKEUCHI TB235-2...
