Oil & Fuel Fuel shut off valve will not close.
   / Fuel shut off valve will not close. #1
JohnDeere4300
John Deere 4300
Today is the first problem I've had with the shut off valve, and it worked fine yesterday.
After using my tractor today i went to turn the fuel off and it WILL NOT turn.
I worked on it for over an hour & even sprayed some WD-40 on it but it won't close.
It fills tight & could break off if i really force it.
anyone have any suggestions?
   / Fuel shut off valve will not close. #2
Sounds like something internally stopping it up.
Drain tank and remove and clean valve. What ?, you thought this was going to be easy ?
If valve isn't removable, drain and try blowing backwards through valve with some compressed air. Heck, even a can of keyboard cleaner would work.
Well i am almost empty on fuel.
Yea i thought it would be easy:D
I'll check it out in the morning & spray everything i have on it.....I'll try the keyboard cleaner.
Have you had this happen before ?
   / Fuel shut off valve will not close. #4
I'm almost afraid to say I don't even shut off my fuel. So, no, not on this machine.
But, I had a valve similar on a motorcycle tank that froze stiff with that whitish buildup you get with alum valves/fittings.
A good cleaning and lots of lube and slowly working it back and forth got it working again.
Willl,
I got the shut off valve to work today.
I sprayed it down with "nut buster" and was able to work it back & forth without breaking it off.
   / Fuel shut off valve will not close. #6
Very cool.
Any idea what was hanging it up ?
Very cool.
No,
The day before it worked fine, and yesterday when i went to turn the fuel off it was so stiff that i couldn't turn it by hand, and i was afraid it would break off if i used channel-locks.
Just one of those :confused: days.
Yellow Posts (A55973)
Enclosed Trailer (A56859)
Enclosed Trailer...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2018 Ford F-350 (A55973)
2018 Ford F-350...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Pickup Instructions (A55272)
Pickup...
