fuel pump leak
/ fuel pump leak #1
zetor Rick
Zetor 5245
hi, i have a zetor 5245 that has a leaky fuel pump. once i took it apart i could see the three "O" rings on each shaft. porblem is i CANNOT find those "O" rings, or any of that size anywhere. any suggestions?
/ fuel pump leak #2
What I would do is take one of the O rings (assuming they are all the same size) with me to an auto parts store or a tractor dealer/shop and see if they have one to match it.
/ fuel pump leak #3
/ fuel pump leak #4
Any time I have odd o-ring needs I go to a place that specializes in seals. Any decent sized city should have several. You need the proper size as well as the proper rubber compound. You don't want the o-rings to dissolve or swell. Where are you located?
Eric
2005 Kubota L39 (A64126)
2005 Kubota L39...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
2022 EZ-GO ELITE...
