fuel pump leak
/ fuel pump leak #1
zetor Rick
Zetor 5245
hi, i have a zetor 5245 that has a leaky fuel pump. once i took it apart i could see the three "O" rings on each shaft. porblem is i CANNOT find those "O" rings, or any of that size anywhere. any suggestions?
/ fuel pump leak #2
What I would do is take one of the O rings (assuming they are all the same size) with me to an auto parts store or a tractor dealer/shop and see if they have one to match it.
/ fuel pump leak #3
/ fuel pump leak #4
Any time I have odd o-ring needs I go to a place that specializes in seals. Any decent sized city should have several. You need the proper size as well as the proper rubber compound. You don't want the o-rings to dissolve or swell. Where are you located?
Eric
3ft. 5-Point Metal Star (A61574)
3ft. 5-Point Metal...
Case SV280B (A60462)
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
Case CX350 C (A65053)
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
