Fuel Problem for Allis 180
/ Fuel Problem for Allis 180 #1
Anonymous Poster
Epic Contributor
I have recently had a problem with my Allis Chalmer 180 gas tractor, It starts and idles fine but when i give it more gas it sputters and dies. In have tried new jets in the carb, blowing out the gas line from the sediment bowl to the tank. If anyone has a suggestion I would greatly appreciate the help.
/ Fuel Problem for Allis 180 #2
I found out always try the little things first as you did.
Could moisture be in your gas tank..little dry gas may help.
If the tractor has a fuel fitler does it need changing.
When the new jets were install was the engine warm before adjustments,if not you may have to adjust.
What color smoke comes out of your exhaust and does it restart hard,for it maybe getting to much gas.
Check to make sure your choke is fully open,also see if there gas kinda dripping from the carb.
Hope this helps.
Thomas..NH /w3tcompact/icons/wink.gif
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
Bobcat S66 Skid Steer (A63688)
Bobcat S66 Skid...
KBH Cotton Spear (A64126)
KBH Cotton Spear...
2022 Weber CF 2-II HD Forward Plate Compactor (A61572)
2022 Weber CF 2-II...
