Oil & Fuel Fuel OK?
/ Fuel OK? #1
MrFixit
South Florida
KAMA 354C
My local gas station has Diesel fuel along the normal petro pumps. My manual says use type "0" but I think I read a prevoius discussion that says use type "1". In any case the Pump does not tell me what type it is, it's just Diesel. Being sold at a small gas station, not a truck stop, It's probably for use in automobiles. Bt is it OK for my KAMA 354 Tractor?
Tim
/ Fuel OK?
Thanks Chip!
I drained my old factory fuel today. It was discusting! I started draining it into a clean, white, plastic Paint Bucket. By the time it was 1/2 inch deep I could no longer see the bottom at all. It was darker and thicker than Starbucks High Octane Coffee! As I moved the bucket I could see waves of very fine sediment along with occasional chunks.
Do the chinese actually run their tractors on this stuff? Or do they sip on it to wake them up in the morning!
Tim
/ Fuel OK? #4
I suspect most of the fluids put into Chinese tractors - particularly Jinmas - is used stuff that was just put in there for warehousing and transport. Dealers that have an eye toward repeat customers usually remedy the mess prior to sale.
Can't put in used fuel though, so I suspect what you're seeing is mostly algae that propagated during transport and warehousing. Some of the tanks - for reasons that escape me - were painted inside as well. Even after you drain, algae will remain clinging to the tank walls, the float mechanism, and probably even the siphon. I'm sure your fuel filter is contaminated as well. Replace it, top up the tank with fresh fuel, and add a biocide. You'll continue to see dead algae accumulate in the sediment bowl, dump/rinse it once in a while. Even after flushing and all the above described steps, it still took ~9 months for that crap to stop accumulating in the KAMA sediment bowl.
//greg//
/ Fuel OK? #6
The Chinese diesel is very dark and smells funny. The Chinese are kind enough to send us 2 or 3 gallons with every tractor, in spite of my pleas to stop.
/ Fuel OK?
After reading Greg's response I found the sediment bowl well hidden under the dash. It has a clamp going from the upper section to hold the bowl on and a maybe a drain at the bottom. I can't get my hand in there to pop the lever or unscrew the drain. Do I have to take the side panels or dash parts off to get at this thing? Maybe smaller Chinese fingers would do the trick!
I suspected the only filtration method was the spin on filter. Wish I would have found this thing (Read Greg's reply) before putting 5 fresh gallons in the tank and replaced the filter!
There are a lot of very experienced and helpful people on this site and I'm very thankful to all of them!
Tim
/ Fuel OK? #9
The fuel from china is actually a high sulfur type that is no longer available here except by special order. Even off road diesel is low sulphur DL2 with dye added.
/ Fuel OK? #10
rob is right, no drain, unclamp and remove sediment bowl to clean (be sure to turn off fuel first with the valve provided at the top of the sedement bowl assy.
/ Fuel OK? #11
Same amount of sediment still in my 1.5 year old KM454 ... Scozz
/ Fuel OK? #12
</font><font color="blue" class="small">( Same amount of sediment still in my 1.5 year old KM454 ... Scozz )</font>
Did you actually ever flush the fuel tank and use a biocide? That - and six months of emptying the sediment bowl - was all it took to get rid of the red paint chips and algae from mine.
//greg//
/ Fuel OK? #13
When i ordered my KAMA 454, Chip of Artrac used me as an experiment. He coated/sealed the tank with a product from NAPA...I think.
I have just looked since we are all discussing. I have about 1/8" of deposits in the glass bowl. I would consider this clean. In the almost one year, I have never drained it. I should say she sits in her heated garage..much to my wife's tured up nose! Just kidd'en
Patrick
/ Fuel OK? #14
Greg I flushed it w/ clean fuel .. forced it thru with compressed air when I got it but never added any treatments. The fuel I use (#2 heating oil) is treated with Tolade (I work for a fuel distributor) but that just helps prevent gelling. I've probably cleaned the sediment bowl 4 times since I've had it. I have had the needle valve clog twice when doing hours of mowing during the summer. Lost power to the point of stall ... screwed valve in then out and she was off and running .. I'll cruise the shelves at NAPA and see what I can come up with for a treatment ... Thanks .. Scozz
/ Fuel OK? #15
Your store might have it, but the guys at mine just looked at me funny. I found a better place to try is somewhere that sells/services marine diesels.
//greg//
/ Fuel OK? #16
I have a KAMA but also own an old english trator called a Nuffield. When the fuel tank in it developed pinhole leaks from condensation rust I had it coated with the NAPA fuel tank product. It works just fine now 2 years later. Just be sure to remove your strainer screen and plug the hole with a pipe plug prior to coating. Guess how i learned this.
/ Fuel OK? #17
Hi Tim,
Here is a picture of the hand tightened nut that holds the fuel bowl on my KM554. Notice that there is less than 1/4" residue in mine now. I think this is acceptable.
/ Fuel OK? #18
</font><font color="blue" class="small">( When i ordered my KAMA 454, Chip of Artrac used me as an experiment. He coated/sealed the tank with a product from NAPA...I think.
Patrick )</font>
If you still have rust or sediment after all this time it might just be the tank rusting from inside. I'm only saying its a possiblity.
There is a product I have used once that came highly recommended and it worked perfect for 4 years now. I believe it might be benificial in severe tank problems. Its a product called CREEM. I'm sure there are others that work well but this stuff is good stuff. Several restorers also use this.
Try googling Creem gas tank sealer, or another type tank sealer that come highly recommenced is POR-15
Just trying to help.
Regards, HarryG
/ Fuel OK?
<font color="blue"> </font>Hi Tim,
<font color="black"> </font> Thanks Rob,
After draining the fuel tank and "Then" discovering the sediment bowl I already had clear duel in the bowl.
I'll know to keep a close eye on it.
Tim
/ Fuel OK? #20
Chip sealed the tank. Having never cleaned/drained the bowl, I consider my tank system to very clean at 1/8" of stuff over a 1 year period.
From what I've read, most have cleaned several times and still fight it.
Patrick
2015 Chevrolet Express 2500 Passenger Van (A61568)
2015 Chevrolet...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2015 Ford Escape SVU (A61569)
2015 Ford Escape...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
