Fuel Line Question
   / Fuel Line Question #1
wayne48
Vermont
MF 1433v
After 10 years of trouble free operation, my MF 1433 finally needs a repair!
The fuel line between the pump and the injector manifold sprung a leak and I'll need to replace it.
So part of my holiday will be spent doing this.
I found a near match for the line at the local auto parts store.
By near match, I mean that the inside diameter of the hose is about 1/32" smaller than the hose I'm replacing.
So my question is -
Will that slight diff cause any problems? I.e. is that going to put more stress on the fuel pump since it will be pumping against a slightly higher head?
Could it lead to premature failure of the pump? Will the smaller diameter size lead to performance issues?
Or am I over thinking this?
Happy Thanksgiving!
   / Fuel Line Question #2
Probably the same hose i have. One time when it was real cold i had a leak, but as it warm up that week, it stop. I think it was leaking at the tank connection. I think there the same hoses that are on the newer 1500 series. I have a Massey dealer only five miles away. I'm sure i could get one there. Not sure about the diameter size hose.
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2010 Ford Edge Limited AWD SUV (A51694)
2010 Ford Edge...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
