Fuel line leaking at fitting
/ Fuel line leaking at fitting #21
you can try this place, it seems they have supplied some to other people. also, the JD950 used the same fitting!.. John Deere 95 CH1474 Holder: Request #133159 Supply.Parts if you can't find one anywhere you can have a machine shop make it on a lathe, it wouldn't take long to make that. it's probably 50 RC hardness, above that, you can't scratch with a file, it can be checked that way..
You guys just blew my mind. There's a lot of knowledge in this forum, I just wish I came here sooner. I replaced the line already, which did nothing to remedy the problem. I did notice the fitting got tight but wasn't snug, which allowed air in through the bottom. I was able to tighten it past that and it loosened back up before snuggling against the fuel pump, giving a proper seal.
However, the fuel still comes out like before. Something tells me that the it is definitely the fitting you all have suggested. I'll get on it right away, thank you!
/ Fuel line leaking at fitting #23
Let me know if u find 1 or not.. & I'll have a look in my cores for 1..
