Fuel line connector problem
   / Fuel line connector problem #11
what about a tire schrader valve with no core....
soundguy
Hmmm. All good info - thanks to all. Seems the only good way to fuse the plastic involves heat + diesel fumes + experience. Getting old has one advantage - knowing what I shouldn't attempt and that is one of them.
The schrader valve is interesting. If I hollow the core and use a plain drill bit slightly smaller than the threaded end of the valve, I may get enough bite in the thin plastic to make it work. Again, I think this line mainly equalizes air pressure and rarely carries fuel, so this may work. Hopefully a metal fitting will co-exist with plastic and not cause problems like different expansion rates.
   / Fuel line connector problem #13
Consider GOOP brand Plumbers weld glues anything to anything and makes seals on pipes hot ot cold.
I keep a tube in shop for plastic seal of leaks. just clean area and apply
ken
   / Fuel line connector problem #14
those tire valves should have a expansion plug base and a groove.. that's where they seal to a rim.. I would think it would work great in your application.. drill the hole so the valve can be forced thru but tightly ( use grease ).. and it should seat.. then just remove the valve core.. then use fuel line to couple her up.
i've put tire valves on non vented gas cans and then removed the valve and screwed the cap back on.. remove cap when pouring.. etc.
soundguy
OK, tire valve is the plan. I'll stop by and see my tire guy on the way home today. I assume the best type has a push in bulb at the base. Also, seems best to remove the valve before I insert/seat the valve housing?
   / Fuel line connector problem #16
doesn't reall matter when you remove the core.. it's done externally with a core tool.. whatever you have room for.
all the valve stems I see have a lip at the base to retain them inside the rim, and the base of the tube is an interference fit with the stem hole, and some even have a raised rib there to help.. should be a good fit.. may have to seat the valve thru the opening in the tank and push it outwards till it clicks into the hole you opened up for it.. but shouldn't be doo hard. again.. i've done these with the red plastic abs style gas cans..
soundguy
   / Fuel line connector problem #17
The valve stem is a great idea and would be the easiest and permanent repair.
You could also use a threaded brass valve stem that uses rubber gaskets and nuts, if you have the room.
Drill the hole and make sure everything fits right.
Thread a wire through the hole and out of the fuel neck,
slide the fitting on the wire and pull it through the hole.
   / Fuel line connector problem #18
Thanks David Kb7uns. I think that would fit better than the tire valves I've been able to find so far. Last night, I ended up trying the Plumbers Goop to re-attach the broken part of the fitting to the tank. I ran a wire through the opening to make sure the Goop didn't close any of the opening as it set, and so far it appears to be a good seal with decent strength.
I will avoid filling the tank too close to full to minimize the slosh reaching the repaired nipple. Usually, the only time I completely fill the tank is winter storage to keep tank condensation down (not sure if that even applies to a plastic tank).
If the adhesive does not work, you guys have provided plenty of 'Plan B' options that don't involve a lot of time or money. Thanks!
   / Fuel line connector problem #20
good luck.
soundguy
2016 Chevrolet Traverse LT SUV (A55853)
2016 Chevrolet...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2016 Ford F-150...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2008 Ford F-250 Crew Cab Pickup Truck (A55852)
2008 Ford F-250...
