fuel leak on L2800
   / fuel leak on L2800 #1
teg
Super Member
nowhere
s
I wonder if this hose should go over this "bump" (see orange arrow in photo). This leak just started and dripped pretty constant, left a small pool. Only leaked when the tractor was running!!! Just a heads up.
I tried to push the hose on more but it would not move. I tighten down the clamp more and the leak stopped. I guess I got a tractor that was built on a Friday since my oil cooler hose also fell off. {mental note: tighten the rest of the hose clamps on your tractor}
If it's not leaking you have it correct.
Thanks, yes, I tighten it pretty tight, then another 1/2 turn... hope the rubber doesn't split!
Mainly, to let others know to keep an eye out for this location. I blow air to get the dirt off my engine after I mow... it's about the only "cleaning" I do. I didn't see any problem the last time I used it.
   / fuel leak on L2800 #4
On my L3400 the hose goes to the bump as shown in your picture. Sounds like just a loose clamp.
Thanks, that's what I wanted to hear, I could not push that hose on at all. :thumbsup:
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
2020 COLOMBO TM LOT NUMBER 218 (A53084)
2020 COLOMBO TM...
Pallet of (15) 10 Lug Misc Wheels (A51573)
Pallet of (15) 10...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
1267 (A50490)
1267 (A50490)
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
