fuel leak on L2800
/ fuel leak on L2800 #1
teg
Super Member
nowhere
s
I wonder if this hose should go over this "bump" (see orange arrow in photo). This leak just started and dripped pretty constant, left a small pool. Only leaked when the tractor was running!!! Just a heads up.
I tried to push the hose on more but it would not move. I tighten down the clamp more and the leak stopped. I guess I got a tractor that was built on a Friday since my oil cooler hose also fell off. {mental note: tighten the rest of the hose clamps on your tractor}
If it's not leaking you have it correct.
Thanks, yes, I tighten it pretty tight, then another 1/2 turn... hope the rubber doesn't split!
Mainly, to let others know to keep an eye out for this location. I blow air to get the dirt off my engine after I mow... it's about the only "cleaning" I do. I didn't see any problem the last time I used it.
/ fuel leak on L2800 #4
On my L3400 the hose goes to the bump as shown in your picture. Sounds like just a loose clamp.
Thanks, that's what I wanted to hear, I could not push that hose on at all. :thumbsup:
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
JOHN DEERE 4440 TRACTOR (A62130)
JOHN DEERE 4440...
(20) 2.5cm X2M Ratchet Straps (A60463)
(20) 2.5cm X2M...
2013 John Deere 5100E (A60462)
2013 John Deere...
2019 F-550 Bucket Truck (A61307)
2019 F-550 Bucket...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
