Fuel issue
   / Fuel issue #1
Jbenoit
79' MF 245 Perkins diesel
Stop arm o ring was leaking at IP. Installed kit. Springs attached on fuel arm. Key on stop arm to the up (outside) position. Bled system. Got fuel to the IP. 1st line completely off, other 2 loose. Turning motor over for 5 or seconds at a time. No fuel to injectors. Running when I parked it! Any help appreciated.
   / Fuel issue #2
I’m assuming u r working on a CAV DPA TOP COVER.??
If yes, u didn’t engage the shut off bar w the nub on the shaft.
   / Fuel issue
You are correct. And the shut off bar your referring to is the horseshoe shaped slide? I assumed the "nub" on the arm just sets in the slide. Does it actually attach to the slide bar.???
John Deere 3PT PTO Post Hole Digger (A55218)
John Deere 3PT PTO...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2239 (A51244)
2239 (A51244)
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
Unused Delta Crash...
