Fuel Injectors
/ Fuel Injectors #1
marty
Mid West
Boomer 33D
I have a Ford 4600 SU that I will be replacing the fuel injectors on. Are there anythings I should know ahead of time? Are the injector lines pressurized when the tractor is off? Is it better to replace one injector at a time, then start the tractor?
Thanks in advance,
Marty
/ Fuel Injectors #2
I had all three injectors removed from my Ford 1210 so I could take them to a bud's garage to be checked. Just the normal stuff - don't twist or kink lines, common sense items. I marked them "1,2,3" just in case. Didn't think it should make a difference, but also didn't want to tempt fate. The 1210 has a bleed screw to rid the system of air.
The tractor hadn't been running quite right, but the injectors were OK. Problem went away after I removed the fuel tank and flushed it well.
I'm sure one of the real mechanics here will add vital info you can use............chim
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
John Deere 8310R Tractor (A64047)
John Deere 8310R...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
Bobcat LT113 Mini Skid Trencher (A61166)
Bobcat LT113 Mini...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
UNUSED KJ K2010 HD CHICKEN COOP (A62131)
UNUSED KJ K2010 HD...
