Fuel Injection pump leeking ?
/ Fuel Injection pump leeking ? #1
Frankm
Erie Pa
Nortrac 204
on my Nortrac 204-C 20 HP , on the Side of the Pump there is a breather hole, its a short pipe about 1/2 in. long , i have oil comeing out of it when i run the tractor it drips and some times there is a spot about the 2 to 3 in. round on the floor, does anyones tractor do this, or is this something wrong with the pump , i only have 10 Hr on the Tractor now , Any Help , Thanks Frank M /forums/images/graemlins/confused.gif
/ Fuel Injection pump leeking ? #3
If it is the banjo fitting, it is normal.
yes thats were the oil is comeing from , so then thats ok ? why does it leek from there ?
/ Fuel Injection pump leeking ? #7
You may have been a bit overfilled with lube oil in the pump. As it warms up it expands and leaks out the overflow port(circled in blue on the above pic). It should stop eventually.
/ Fuel Injection pump leeking ? #8
/ Fuel Injection pump leeking ? #9
One thought here... Any chance that pump can 'make' oil? I.e. it is overfull from diesel entrainment?
Soundguy
/ Fuel Injection pump leeking ? #10
Soundguy
/ Fuel Injection pump leeking ? #11
That is possible, but then I guess the oil leaking wouldn't stop eventually:).
/ Fuel Injection pump leeking ? #12
/ Fuel Injection pump leeking ? #13
It may be important for him to find this out. , rather than wait to see if it will stop leaking... i know from inline ford pumps.. like Sims.. etc.. once you get diesel thinned oil in your injector pump... it's about shot..
Soundguy
/ Fuel Injection pump leeking ? #14
Soundguy
I ran it about an hour and its not leeking any more , so it must have been over full, seams good now. /forums/images/graemlins/grin.gif
/ Fuel Injection pump leeking ? #17
FrankM - Here's my 2 cents worth. That banjo fitting is the high level for the injector pump. The injector pump has it's own oil in it. There has been some discussion on this forum as to what kind of oil to use in it. Right or wrong - I use tractor motor oil in it. I change it every hundred hours. But the punch line is - that is the full mark, and oil should not be leaking out of that fitting. That banjo fitting has two copper washers - one on each side - that the mickey mouse little rubber cap is good and tight. I use one wrap of mechanics wire to secure it. (you know, the old farmer's bailing wire(littler smaller size). Be sure to keep the oil up to the Full level. Keep us informed - Yugo
in the book it said to fill it till it starts running out there , its not leeking any more , seams to be ok now , book allso said to use the same motor oil that is used in the motor , Thanks /forums/images/graemlins/grin.gif
in the Book it said it is a breather , If so why in the world would you plug it off ? /forums/images/graemlins/confused.gif
/ Fuel Injection pump leeking ? #20
The breather is in the top. The overflow nipple on mine has the same cap. It fits loosly and just barely stays on. I've changed my injector pump oil twice and I'll tell you it drips for weeks and then levels off. Operating on inclines may cause further dripping. This is where I believe the cap serves its purpose.
Obviously, if you get a constant drip it may be "making oil" but this is rare.
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A60352)
2022...
2016 Nissan Sentra Passenger Car, VIN # 3N1AB7AP6GY307338 (A61165)
2016 Nissan Sentra...
New/Unused Pallet of 5 Binders and 10 Chains (A61166)
New/Unused Pallet...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59908)
2015 ISUZU NQR 4X2...
Kubota U55-4 (A57148)
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN#7FWBE1628T1037981 (A61166)
2026 Steel Pines...
