Fuel in oil kioti dk55
   / Fuel in oil kioti dk55 #1
Trent orosz
Kioti 55
I have a kioti 55 that the engine oil is filling with diesel fuel while running
Enough that it blows out the blow by after an hour on a fresh oil change
My thoughts are injection pump leaking but how or where and is this a. Common problem
I have looked on numerous sites and forums but can’t seem to find something similar
   / Fuel in oil kioti dk55 #2
Sounds like a bad fuel injector but I could be wrong.
   / Fuel in oil kioti dk55 #3
I believe your injection pump has a failed seal and is leaking internally. Unless you are very adept at fixing it, I'd have a dealer do it. Constantly getting diesel in the lube oil will eventually destroy the crankshaft bearings.
   / Fuel in oil kioti dk55 #5
It could also be a failed diaphragm on the mechanical fuel lift pump, if so equipped. I would check that first since it is usually pretty easy to get at and replace or switch to an electrical lift pump.
Just a suggestion.
Ended up being a. Lift pump thanks for the input
CLARK C40L FORKLIFT (A48992)
CLARK C40L...
2007 MACK CV713 DAYCAB (INOPERABLE) (A48992)
2007 MACK CV713...
2013 KUBOTA UTV (A48992)
2013 KUBOTA UTV...
2016 Ford F-450 Knapheide Service Truck with Liftgate (A48081)
2016 Ford F-450...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50046)
2021 FREIGHTLINER...
2015 KENWORTH T800(INOPERABLE) (A48992)
2015 KENWORTH...
