Fuel in oil kioti dk55
   / Fuel in oil kioti dk55 #1
Trent orosz
Kioti 55
I have a kioti 55 that the engine oil is filling with diesel fuel while running
Enough that it blows out the blow by after an hour on a fresh oil change
My thoughts are injection pump leaking but how or where and is this a. Common problem
I have looked on numerous sites and forums but can’t seem to find something similar
   / Fuel in oil kioti dk55 #2
Sounds like a bad fuel injector but I could be wrong.
   / Fuel in oil kioti dk55 #3
I believe your injection pump has a failed seal and is leaking internally. Unless you are very adept at fixing it, I'd have a dealer do it. Constantly getting diesel in the lube oil will eventually destroy the crankshaft bearings.
   / Fuel in oil kioti dk55 #5
It could also be a failed diaphragm on the mechanical fuel lift pump, if so equipped. I would check that first since it is usually pretty easy to get at and replace or switch to an electrical lift pump.
Just a suggestion.
Ended up being a. Lift pump thanks for the input
PUMP JACK (A48992)
PUMP JACK (A48992)
1999 24DTA pintle hitch trailer (A50397)
1999 24DTA pintle...
2015 CASE 580 SUPER N BACKHOE (A50458)
2015 CASE 580...
2007 Vanguard National VIP4000 53ft. T/A Dry Van Trailer (A48081)
2007 Vanguard...
PUMP JACK (A48992)
PUMP JACK (A48992)
2004 CATERPILLAR D3G XL CRAWLER DOZER (A50458)
2004 CATERPILLAR...
