Fuel in oil kioti dk55
   / Fuel in oil kioti dk55 #1
Trent orosz
Kioti 55
I have a kioti 55 that the engine oil is filling with diesel fuel while running
Enough that it blows out the blow by after an hour on a fresh oil change
My thoughts are injection pump leaking but how or where and is this a. Common problem
I have looked on numerous sites and forums but can’t seem to find something similar
   / Fuel in oil kioti dk55 #2
Sounds like a bad fuel injector but I could be wrong.
   / Fuel in oil kioti dk55 #3
I believe your injection pump has a failed seal and is leaking internally. Unless you are very adept at fixing it, I'd have a dealer do it. Constantly getting diesel in the lube oil will eventually destroy the crankshaft bearings.
   / Fuel in oil kioti dk55 #5
It could also be a failed diaphragm on the mechanical fuel lift pump, if so equipped. I would check that first since it is usually pretty easy to get at and replace or switch to an electrical lift pump.
Just a suggestion.
Ended up being a. Lift pump thanks for the input
500BBL WHEELED...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
2018 Dodge 5500 Bucket Truck 4WD (A56436)
2018 Dodge 5500...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
