Fuel hose / Tractor cab question
/ Fuel hose / Tractor cab question #1
sw18x
Bronze Member
Looking
I built a cab for my BX2360. To refuel, I need to run a hose off of a funnel through an opening in the back of the cab into the fuel fill. Will standard rubber hose be ok to use with diesel fuel? Because I already found out the hard way that plastic cups are NOT a good measuring tool for diesel additives (especially when said cup is left on wife's kitchen counter).
/ Fuel hose / Tractor cab question #2
Good question. I would imagine to only use those hoses from auto stores made for fuel lines. I really don't see the harm using a radiator hose as well as its made for harsh environments.
So you spilled power service on your countertops in kitchen? :eek:
When I get a new power service bottle, I mark off the increments in 5 gallons marks and use a black marker like a sharpie. This way when I fill up with my 5 gallon jug, I know exact amount to put in and if I put in too much- it won't hurt a thing, but I know how much to hold back next time since the BX tank is moree then 5 gallons. :thumbsup: No problems using this method so far for over 4 years.
/ Fuel hose / Tractor cab question #3
One should actually use a neoprene hose(it's made for fuel use), but in a pinch I've used any hose available.
Oil products can degrade regular rubber(sometimes fairly quickly), so be careful what you use.
/ Fuel hose / Tractor cab question #4
A simpler way is put the additive in the fuel not the tractor tank .
PALLET OF (24) 2" X 8" X 27" CHANNEL IRON (A64280)
PALLET OF (24) 2"...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
WEG INVERTER DUTY MOTOR (A64281)
WEG INVERTER DUTY...
2023 73in Hydraulic Roller Skid Steer Attachment (A61572)
2023 73in...
