Fuel hose / Tractor cab question
/ Fuel hose / Tractor cab question #1
sw18x
Looking
I built a cab for my BX2360. To refuel, I need to run a hose off of a funnel through an opening in the back of the cab into the fuel fill. Will standard rubber hose be ok to use with diesel fuel? Because I already found out the hard way that plastic cups are NOT a good measuring tool for diesel additives (especially when said cup is left on wife's kitchen counter).
Thanks
/ Fuel hose / Tractor cab question #2
Good question. I would imagine to only use those hoses from auto stores made for fuel lines. I really don't see the harm using a radiator hose as well as its made for harsh environments.
So you spilled power service on your countertops in kitchen? :eek:
When I get a new power service bottle, I mark off the increments in 5 gallons marks and use a black marker like a sharpie. This way when I fill up with my 5 gallon jug, I know exact amount to put in and if I put in too much- it won't hurt a thing, but I know how much to hold back next time since the BX tank is moree then 5 gallons. :thumbsup: No problems using this method so far for over 4 years.
/ Fuel hose / Tractor cab question #3
One should actually use a neoprene hose(it's made for fuel use), but in a pinch I've used any hose available.
Oil products can degrade regular rubber(sometimes fairly quickly), so be careful what you use.
/ Fuel hose / Tractor cab question #4
A simpler way is put the additive in the fuel not the tractor tank .
Thanks
2019 Chevrolet Express 2500 Cargo Van (A61573)
2019 Chevrolet...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
