Fuel guage troubles
/ Fuel guage troubles #1
Indydirtfarmer
Platinum Member
Southern Indiana
JD 2440/4440/4020/4955
Trouble in paradise.... /forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/frown.gif
Last week, as we were finishing up planting a corn field, the fuel guage on my '78 Deere 2440 started doing strange things. It began flipping back and forth between full and empty. (with a relatively full tank) It seemed to do it worse with high engine RPM's or higher ground speeds (on the road) /forums/images/graemlins/crazy.gif /forums/images/graemlins/shocked.gif
Fast forward to yesterday... I had to do some bush hogging around the homestead. I fueled up the 2440. (I didn't pay any attention to the guage BEFORE fueling) When I started mowing, I noticed the fuel guage was dead on empty. (with full tank) When I shut off the tractor (to eat dinner) it jumped to full. When I fired back up to finish, it went back to empty... /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif
Obviously a PROBLEM. /forums/images/graemlins/frown.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif
I have the owners manual, shop manual, and parts manuals to this tractor, but haven't had a chance yet to get them out for a look-see.
Now here's where you come in.. Any one know how I go about checking (1) the sending unit? (2) the guage? Is that guage "fuse protected" in any way? I'll check the wiring between the sending unit and guage when I get home this afternoon. /forums/images/graemlins/tongue.gif
Anyone have any advice? /forums/images/graemlins/confused.gif
Thanks in advance! /forums/images/graemlins/grin.gif
Bill
/ Fuel guage troubles #2
Bill;
Check the wiring to the gauge as well. Don't overlook the ground on the sending unit. Easy check. Run a separate jumper lead fron the sender body to a known good ground.
To test the sender itself, out of the tank, connect ohm meter to the terminals, and slowly raise/lower the float. You should see a steady change in the resistance with no spikes to infinity. I'd be surprised if it is the sender. A bad spot in the sendinr resistor should correct itself as the fuel level goes down moving the wiper past the bad spot. My best guess is a bad ground. Most common problem.
Richard.
/ Fuel guage troubles #3
If you have other gauges that fluctuate, It's probably a bad ignition switch, (or especially if no other gauges).
/ Fuel guage troubles #4
Sure sounds like an intermittent ground problem which would explain why the bumping around makes it worse. Possibly only a loose ground connection, that is occasionally not grounding. If it were another wire, hot, you'd probably blow a fuse. So I'd go for checking the grounding first.
John
/ Fuel guage troubles #5
will 2nd KiotiJohn's theory. if not a bad ground, look for a partially broken wire, no telling how those wires are after many hours of use.
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2016 Lincoln Navigator SUV (A61569)
2016 Lincoln...
2003 Badger 1085D Wheeled Excavator (A61166)
2003 Badger 1085D...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
Kuhn FC400RG (A60462)
2016 KENWORTH T270 SERVICE TRUCK (A62130)
2016 KENWORTH T270...
