Oil & Fuel fuel gauge
/ fuel gauge #1
dvarner
How can i install a fuel gauge in my yenmar 2700
/ fuel gauge #2
my fuel gauge is built into the fuel tank cap. I don't know if this set up will work on your 2700 or not. Mabe someone that sells parts will know
/ fuel gauge #3
JD 950 ( yanmar made ) has a sender in the tank and a gage on the dash. That said, think you would need the tank, sender, and gage from a 950,1050 IF it would fit. Lots of trouble. I'd go with the in cap gage if you can. I have one in my YM 3000 ( in the cap type ) and it does give you some idea how much fuel you have. In the dash type could run lots of bucks and lots of trouble with the install if it would fit. Don't think you could just cut a hole in the existing tank and get the sender to seal again.
Chris
/ fuel gauge #4
Just put a post it on the dash to remind yourself to check the fuel :p
PORTA POTTY (A68842)
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
More info coming soon (A64557)
More info coming...
PORTA POTTY (A67714)
2013 RANCO BELLY DUMP (A67714)
2013 RANCO BELLY...
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
