Fuel Gauge Problem
/ Fuel Gauge Problem #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi All. I have a B3000 and have recently developed a problem with the fuel gauge.
It has been indicating a completely full tank, in spite of it actually being close to empty.
I don't know if it's a problem with the sensor/float inside the tank, or the gauge itself.
Any tips or suggestions on how to diagnose, and repair, the problem?
Thanks !
/ Fuel Gauge Problem #2
The workshop manual for your machine should tell you how to check the fuel level sensor resistance vs a reference value. If you machine is like my L3240, your fuel guage is part of the electronic instrument and not individually replacable (i.e., mucho $$$s).
/ Fuel Gauge Problem #3
I think you still have the analog gauges?
There is a resistance measurement that can be made for the sending unit.
Min to max as the float moves up and down.
Perhaps one of the wires has broken,or become disconnected?
There was a thread several years ago with member srs with a B3030HSDC which went thru the testing.
More than likely the same as your tractor.
Good Luck &keep us posted!
Chewwy, Thanks. I do have a "Shop Manual" somewhere. I"ll have to find it and dig deeper.
Number two2, Yes, my B3000 is VERY similar to the B3030HSDC. I"ll search for the thread.
I think I"ll pull the dash to see if, perhaps, there is a loose wire or dirty/corroded connection.
IF the gauge is the problem, I hope I can replace "just" the gauge and not have to do the entire gauge panel.
Then figure out where the "sender" comes out of the tank so I can check resistance.
/ Fuel Gauge Problem #5
I had an old David Brown 990 where none of the guages worked (oil pressure, engine temp, fuel tank level, battery charging). I used it for years bush hogging.
It was very frugal and predictable on fuel consumption. Ran it hot one time due to a leaking radiator hose. Was able to smell the radiator leakage before the engine was damaged.
OMG.... you're lucky it didn't cause damage.
numbertwo..... found that post from srs. WOW, 6 pages just to discover the float was stuck!
I guess that's how diagnosing a problem goes sometimes.
I hope fixing my problem is not so involved.
/ Fuel Gauge Problem #7
The fuel gauge sending unit sits on the left top of the tank behind the instrument panel. I am not having issues with my fuel gauge but the connections are green and I am going to clean them while I have it apart for an unrelated issue. Had to remove some ‘mouse house’ remnants from on top of the fuel tank, no chewing damage luckily.
Hi number two!
No, no resolution/fix.
I did end up running the front snow blower with the 10" of snow we got recently, and the gauge did move downward a little to show 1/2 full, but I do not believe it is/was accurate.
When I filled the tank up again, it did read "full", but who knows if it will start working again now that it has been topped off.
If it is a "float" type sensor inside the tank, then maybe by adding fuel, it loosened up the float and it will work again.
But I won't know that until I use the tractor again to lower the fuel level.
On a side note.... my front blower (B2732B) really chewed up the sleet covered snow with no problem at all.
I was totally impressed.
