Oil & Fuel Fuel Filter valve assy.
/ Fuel Filter valve assy. #1
Buckman1
Leesville, Louisiana
ISEKI TS2205
I recently purchased a Iseki TS 2205. I couldn't find the model number on it before I bought it wanting to learn as much as possible about this tractor. I would like to replace the Fuel Filter valve assy, and other filter that need to be replaced becaused it was poorly maintained.
I am enclosing an attachment with post hoping someone will know where I can purchase this filter assembly,
  • Fuel filter TS series.pdf
/ Fuel Filter valve assy. #3
Just wondering, even if poorly maintained you should not have to replace the whole assembly unless its broken, what is wrong with the assembly you have?
Yes I will have to replace the whole assembly. The previous owner replaced the original filter assembly with something that came from ?? and it is leaking.
/ Fuel Filter valve assy. #5
You may want to do a search for the compact series of the Massy ferguston tractors as they use to be made by Iseki. If you find the size that yours is try and get a parts breakdown and see if it looks the same. The part number will be different than yours so you cannot go to a dealer and ask as they won't look it up for you unleess they have the size tractor in their brand
/ Fuel Filter valve assy. #6
I just did a quick search and go to AGCO parts put in your tractor model and name. This is where you will have to get your parts from. I think the only way you will be able to order them is thru an AGCO dealer. I don't know if the part you need is still available
/ Fuel Filter valve assy. #8
I need the same item. Who is your parts supplier?
