fuel filter clean/change for b2920
   / fuel filter clean/change for b2920 #11
When I did the filter cleaning on my B3030, I didn't use plastic over the fuel tank opening. With the tank at less than 1/2 full, I still lost over a pint. No problem: with that pint of diesel and the kerosene I used to clean the filter and bowl, I had a nice way to start a fire in my fire pit.
   / fuel filter clean/change for b2920 #12
B2320-- Unscrew filter bowl, remove old filter, clean, install new filter and new o-rings, start and check for leaks. Takes about 3 minutes, tractor starts right up and runs smooth.
   / fuel filter clean/change for b2920 #13
my L3130GST has a fuel shut off valve at the fuel filter--piece o cake!!!
Yep, would be nice to have but not the case with the B2920
   / fuel filter clean/change for b2920 #15
Some of the earlier posts did not mention replacing the filter but cleaning it.
I tried that but if you're going to the bother then you might as well put in a new filter.
After my first try and cleaning the filter with kerosene I would get a hesitation at different rpm's but more at low idle. I figured it was the filter.
I put in a new one and had no problems and the tractor is running fine now.
So my advice is change the filter then there is no wondering if you should've or not.
   / fuel filter clean/change for b2920 #16
I agree. Cleaning fuel filters is a waste of time unless we are discussing a metallic screen type element in a primary water separator.
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
