Fuel Filter Change MT240
/ Fuel Filter Change MT240 #1
JCoastie
Platinum Member
Coastal AL
LS MT240HE
Changed the fuel filter in my MT240 and it is running just fine.
Drilled some holes, ground some stumps, grappled some trees to the burn pile etc, all just fine.
But....
After the filter change, I used the built in primer to get fuel flowing through the lines, but it never really gets hard to pump. I've probably pumped it 400 times, and it stays pretty easy. I though it was supposed to get hard and not be able to pump once it's fully primed?
Then I though there must be some kind of bypass for unused fuel to get back to the tank, but I really don't know.
Should the primmer get hard to pump? I forgot to prefill the filter with fuel, but 400+ pumps really? And where does the air go, since I didn't prefill it?
Again, used probably 2.5 hours after, with no problems.
/ Fuel Filter Change MT240 #2
Loosen the bleed valve (3) pump (2) until fuel comes (without air) out then close valve
sweet, thanks!
Done, that fixed it right up, thanks again.
/ Fuel Filter Change MT240 #5
Welcome., need other info I have service manuals.
2014 HARBINGER GENERATOR (A65643)
2014 HARBINGER...
Saddle Tanks (A65640)
2004 Ford F-550 Flatbed Truck, VIN # 1FDAW56P24ED63182 (A65563)
2004 Ford F-550...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
JMR 4X8 WORK BASKET (A64553)
JMR 4X8 WORK...
Hobart Beta- Mig 200 Welder (A65579)
Hobart Beta- Mig...
