Fuel filter cap replacement
/ Fuel filter cap replacement #1
chsdiyer
Charleston
XG3025H
I cracked the clear fuel filter cap today on my XG3025. I found a replacement filter local but was wondering if anyone knew where I might have luck finding a replacement cap. Is that something I should be able to find at an auto parts store? Or there is a Kubota, Massey, and John Deere dealers in town, is there a compatible replacement they may have. Or is it something where it'd be easier to just replace the whole assembly? The part number I found online is...
3​
40224977​
31A6200312​
CAP,FILTER​
/ Fuel filter cap replacement #2
Order through the LS dealer? They may have one in stock. Is that an LS part #?
If it is, just put "MT" in front of the number, that would become a New Holland part number. (The XG3025 is the same as the NH Workmaster 25) that will increase your availability at dealers.
Hope you can easily find one.
Awesome, thanks. That is an LS number. I think there is a new holland dealer around here, but i'm not sure they sell smaller tractors, it's more for large equipment. I'll still give them a try. Wasn't sure if there was anything special about they LS assembly that I couldn't just buy whatever JD or the other brands put on their tractor and replace the whole thing. I would have thought at some level a lot of these parts are common/shared.
/ Fuel filter cap replacement #4
40224977 is the LS number add MT and it becomes the NH number MT40224977
The second number 31A6200312 is the part that LS buys from a supplier and then give it their own number. IN this case it is FUEL FILTER CUP fits Farmtrac, LS, Montana, Mahindra, Caterpillar, Mitsubishi and is at least $10 cheaper than the LS or NH number.
I ended up getting the filter cap from the dealer a couple of hours away. It was the LS branded one and only $25, but the shipping was about the same :( Got it put back on and back running again. except for my new problem of running the PTO switch without being on the seat 🤦‍♂️
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
iDrive TDS-2010H...
2016 International DuraStar 4300 Dump Truck (A61573)
2016 International...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2023 Case TV450B (A62177)
2023 Case TV450B...
