Oil & Fuel Fuel Consumption???
   / Fuel Consumption??? #21
Heh, It seems like everybody is bent on having power on 24/7. I am sure even the gas standalone needs a break from running for power. If it is dark out, who in the right mind would be working outside with thier tractors in the storm? I'd leave it by house running the pto gen until I go to sleep and shut it down for the night. In the morning the gen would be running again for breakfast and when its time to do cleanup, I am sure the fridge/freezer/furnace is ran long enough to survive for the day and most houses should have daylight to be able to see in the house. So - whats the need for power 24/7? other then health reasons ? Sorry guys, I support pto gennys even though i have a standalone gasser since I had it before I bought the tractor.
   / Fuel Consumption??? #22
A couple of years ago our power was out for about 15 hrs in the middle of winter. I ran my generator all night to keep the furnace on. Also, a big concern of mine is when we have a power outage due to a thunderstorm. If we get 3-4 inches of rain in a short period of time I need power to run the sump pump so the basement does not flood. Last summer we had over 6 inches of rain in 8 hrs. The power was out for 28 hrs and my generator ran the entire time. My basement still flooded due to the extreme amount of rain but it was because the sump pump could not keep up with the water that was coming in. We only lost the carpet in the basement but it would have been much worse with no power and more water.
   / Fuel Consumption??? #23
The problem with sutting down the gen over nite is it leaves you with no heat if you have a forced air gas furnace.
Furnace requires elect to run the blower and operate the thermostat.
If the blower quits running the gas shuts off and the flame goes out.
   / Fuel Consumption??? #24
I would shut the generator down at about 10pm, (I have a wood stove). But my neighbor had to have his run 24/7 do to heat!:(
   / Fuel Consumption??? #25
   / Fuel Consumption??? #26
3*A stand alone frees up the tractor for other task plus the tractor don't have to set out in the storm for days keeping the lites on.
Maybe you missed that the OP already has 2 tractors and was wondering which of the 2 was best to hang a PTO genny on.
   / Fuel Consumption??? #27
I don't think that a point has been missed, it is a general comment, not specific to the OP, for anyone else considering there options. The OP has already made his decision to go with PTO which I am sure in his case makes great sense for his specific applications or is OK with the limitations of a PTO generator.
   / Fuel Consumption??? #28
Good observation.
No I didn't :
I have 3 tractors but If I were to purchase a generator I'd still prefer a diesel stand alone .
Why A stand alone.
set it up / hook it up once and you're done with it.
In the event of a power failure flip the switch start it up = lites on with no digging out a tractor and hooking up a generator to it.
   / Fuel Consumption??? #29
Hi,
Ideally I would go with using the larger engine. Fuel consumption would be equal if not better on the larger tractor simply because it is not trying to put the cylinders through the head at max RPM. A small engine at high rpm is going to go through fuel a bit more than a slightly larger engine at lower RPM. Also you have a much better reserve with the larger unit.
Jeff
Hi,
Jeff
That's exactly how I was thinking but in the back of my head I was thinking maybe the smaller engine would be better because it takes less fuel to power it but at the same time its turning 6 or 700 more rpms. I gues the next time we get an outage I will use the L3400 and keep track of the gallons used, then the next time use the BX and see where it comes out. Thanks Bob
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
22018 (A56859)
22018 (A56859)
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2017 John Deere 6120E (A53317)
2017 John Deere...
