Frozen filled tires - how can you tell?
   / Frozen filled tires - how can you tell? #11
I read that RV antifreeze is supposed to be used full strength, not diluted. But then I never heard of it before either.
The antifreeze we get in Maine is either premixed and you use it full strength or you get it and add water according to the table and how much protection temperature wise you want. 70%antifreeze 30% water is common for cold climates.
I saw this - "Make sure to use an antifreeze hydrometer and not one designed for use with checking the acid content of the fluid in your vehicle's battery. While hydrometers come in a wide variety of styles, the most common have little floating balls within it of varying colors or arrows that point to temperatures on a scale printed directly on the hydrometer that help determine the strength of the coolant solution.
Step 2: Read the hydrometer. To read the hydrometer, check out the number and color of floating balls, or where the arrows point on the freeze point scale printed on the hydrometer."
Collect some of the liquid from the tire in a cup and use the hygrometer to read it - Put the valve 1/2 way from top - press tip of valve needle and collect fluid that comes out.
Amazon.com: ABN Deluxe Antifreeze and Coolant Tester Hydrometer: Automotive
   / Frozen filled tires - how can you tell? #12
The best way to tell if your tires are frozen is to watch for them sweating (like a glass of ice water) on warmer moist days. IT wont work when temps are well below freezing though.
   / Frozen filled tires - how can you tell? #13
Using AUTOMOTIVE anti freeze in tractor tires is a TERRIBLE idea, if you have animals.
Spilled automotive antifreeze (ethelene glycol) will attract animals to the DEADLY sweet taste.
It doesn't take much!
If you love your dogs and cats......don't use it!
   / Frozen filled tires - how can you tell? #14
Rim Guard® is nearly 30% heavier than water.
Rim Guard® is non-corrosive.
Rim Guard® is non-toxic and biodegradable.
Rim Guard® is freeze-resistant down to -35°F.
Rim Guard® is cost effective because inner tubes are not needed and tires are easier to repair.
Rim Guard® is the one and only Beet Juice™ tire ballast!
I use rim guard it was 2 or 3 dollars a gallon installed
   / Frozen filled tires - how can you tell? #15
RV anti freeze is designed for use in Rv plumbing system, non toxic and undiluted
   / Frozen filled tires - how can you tell? #16
You'll know if your tire is frozen when you drive it. Mine came from the south and the previous owner added water as ballast.
I didn't know till the first winter and the rears were blocks of ice. I drained them as soon as it thawed but getting out all the water without dismounting the tire is tough.
I ended up adding windshield wiper booster made by rainx and it has taken care of the freeze issue. It's been -5 here the last few nights and the tires remain fluid.
Matt
An 11 to one ratio (5 gal. in 55 gal.) of RV antifreeze, is woefully inadequate for tire freeze protection.
Before determining what fluid to use, I decided to experiment.
I filled a 1qt. plastic milk container with 50% water, and 50% RV antifreeze, and put it in my freezer.
Bad idea!
Mixture froze solid (freezer temp 0 degrees).
I then tried 75% RV anti freeze.
Mixture was now soft ice.
Tried the same freezer experiment with STRAIGHT -20F rated WWF.
Excellent result!
No freezing at 0 degrees.
WWF cost $1.20/gal., but sometimes less when on sale.
On a personal note though:
Best "solution" for me is Florida.
I won't be going back North to my tractors until late April.
Actually I looked it up yesterday at the Rimguard et al site and my 14.9-24 rear tires take 47 gallons. I have no idea where I got the 55 gallons from. :(
So it's slightly more than 10% concentration.
Freeze protection is dependent on temps. 10% *should be* good to around 20 degrees or so. Our temps here have been 15-25 for about a week or so. I store my tractor in my shop, so at least it's protected from the wind and the radiation to the cold sky.
RV antifreeze is already diluted for the right temperature. Diluted with straight water as in your tire will make it almost useless against freezing.
You should have used a antifreeze concentrate and mix it to the right levels for the temp needed for protection, or premixed for a certain temp protection.
This was concentrated RV AF, good to -50 degrees. My only fault perhaps, was listening to my BIL. He's a pretty sharp farm guy, owns a very successful farm business and owns +14 tractors, mostly JDs.
I was looking at these today. They make one for ethylene glycol (regular AF = poison) and one polypropylene glycol (RV AF = nontoxic.).
Note that the one you linked is for the ethylene version. I plan to pick one of the PG versions up today when I go into town.
I'll look for that tomorrow, it's supposed to be in the mid-40's here. I also plan to crack the tire valve and see if liquid comes out.
Thanks for all the help everyone!
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
UNUSED FUTURE 76B PIPE BENDING MACHINE (A58376)
UNUSED FUTURE 76B...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
KUBOTA ZG1235 ZERO TURN MOWER (A58375)
KUBOTA ZG1235 ZERO...
10' CONTAINER (A58376)
