Grapple Frontier Root
/ Frontier Root #2
I purchased one in November and use it every weekend -- rarely have the bucket attached. I've had some recent difficulty attaching the 3rd function hydraulic line. Other than that, I have no hesitation recommending it. The unit is great for picking up debris and clearing old fence rows.
/ Frontier Root #3
I have the AV20G and also use it with my 10000 lb skidsteer. It is very stout, 950 +/- pounds, and iis till perfectly straight after grubbing out mesquite stumps. The only damage I have done to it is rip off 2 of the replaceable teeth.
/ Frontier Root #4
I have the av20e and it's the best thing I've ever seen for a tractor, it is indestructible, I see other people describing the tines on theirs being 3/8 steel or 1/2 in this has 1 inch thick steel!!! It has snapped 10 inch cedars that I clamped too tight like I can snap a toothpick!! Worth every penny!!
/ Frontier Root #5
Is the Frontier AV20H Root grapple a quality unit?
The tine spacing is 15" which is about double of other makes. It should be great logs and stumps but I would think if you want to pick up smaller debris you would want some additional lower tines of about 8" spacing.
/ Frontier Root #6
The wider tine spacing makes it much better for raking without picking up a lot of dirt. The tines also extend far below the bottow pipe that allows it to rake deeper without pulling dirt.
/ Frontier Root
Does anyone have the specs on the different Frontier models?
Which ones will the 4x20's handle?
/ Frontier Root #8
Your 4X20 should have a 400X or 400CX Loader. The AV20H (60 in.) and AV20E (62 in.) are compatible with both FELs.
I have the AV20H and love it. You'll also need BW15260 Third SCV Kit (Open Station)
/ Frontier Root
Does the AV20E have two hydraulic cylinders?
/ Frontier Root #12
AV20H model has only one hydraulic cylinder which is centered on the unit.
/ Frontier Root
LouieJunior said:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=258889"/>
Would you see an advantage having two cylinders like the E model?
/ Frontier Root #14
Two is far better than one. When a log turns and holds one open, the other is free to clamp the small debris that would otherwise fall out.
/ Frontier Root #15
I suppose you can get a better grip on irregularly shaped objects, since each of the top units can close independently.
2015 Ford F-250 Pickup Truck (A61568)
2015 Ford F-250...
2017 Chevrolet Colorado Ext. Cab Pickup Truck (A61568)
2017 Chevrolet...
(INOP) 2018 JOHN DEERE 50G EXCAVATOR (A62129)
(INOP) 2018 JOHN...
2020 14ft. Continental S/A Boat Trailer (A61569)
2020 14ft...
FEEDER (A62131)
FEEDER (A62131)
Paladin 544K 416 IC 105in. Dual Cylinder Hydraulic Loader Attachment (A61567)
Paladin 544K 416...
