Grapple Frontier Root
/ Frontier Root #2
I purchased one in November and use it every weekend -- rarely have the bucket attached. I've had some recent difficulty attaching the 3rd function hydraulic line. Other than that, I have no hesitation recommending it. The unit is great for picking up debris and clearing old fence rows.
/ Frontier Root #3
I have the AV20G and also use it with my 10000 lb skidsteer. It is very stout, 950 +/- pounds, and iis till perfectly straight after grubbing out mesquite stumps. The only damage I have done to it is rip off 2 of the replaceable teeth.
/ Frontier Root #4
I have the av20e and it's the best thing I've ever seen for a tractor, it is indestructible, I see other people describing the tines on theirs being 3/8 steel or 1/2 in this has 1 inch thick steel!!! It has snapped 10 inch cedars that I clamped too tight like I can snap a toothpick!! Worth every penny!!
/ Frontier Root #5
Is the Frontier AV20H Root grapple a quality unit?
The tine spacing is 15" which is about double of other makes. It should be great logs and stumps but I would think if you want to pick up smaller debris you would want some additional lower tines of about 8" spacing.
/ Frontier Root #6
The wider tine spacing makes it much better for raking without picking up a lot of dirt. The tines also extend far below the bottow pipe that allows it to rake deeper without pulling dirt.
/ Frontier Root
Does anyone have the specs on the different Frontier models?
Which ones will the 4x20's handle?
/ Frontier Root #8
Your 4X20 should have a 400X or 400CX Loader. The AV20H (60 in.) and AV20E (62 in.) are compatible with both FELs.
I have the AV20H and love it. You'll also need BW15260 Third SCV Kit (Open Station)
/ Frontier Root
Does the AV20E have two hydraulic cylinders?
/ Frontier Root #12
AV20H model has only one hydraulic cylinder which is centered on the unit.
/ Frontier Root
LouieJunior said:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=258889"/>
Would you see an advantage having two cylinders like the E model?
/ Frontier Root #14
Two is far better than one. When a log turns and holds one open, the other is free to clamp the small debris that would otherwise fall out.
/ Frontier Root #15
I suppose you can get a better grip on irregularly shaped objects, since each of the top units can close independently.
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A62131)
UNUSED WOLVERINE...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2016 John Deere 318G Skid Steer Loader (A61166)
2016 John Deere...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
