Front wheel seals
/ Front wheel seals #1
Mace
Utah
YM1500D
I just got a box from the dealer to replace the front wheel seals and bearings on my 1500D.
There are an alarming number of parts in the box. Am I getting in over my head, or will it be fairly straightforeward when I open uo the wheels?
I am very good at turning wrenches on the power plant of a nuclear submarine, but I haven't done much serious work on vehicles before. I am wondering if I will be OK, or if I should pay a mechanic?
/ Front wheel seals #2
It is not complex, but it does take a mechanical inclination. I would suggest you call your dealer (wasn't it RCO?). We would, and have, put a mechanic on the phone with the customer for general instructions, and the parts book gives a pretty clear diagram of the assembly.
/ Front wheel seals #3
Agreed, call them, RCO, they say that they have a f/t mechanics on staff to help out with this kinda stuff...
btw, I'm like you, I can read and understand stuff, work on highly complex and abstract technical topics, but when it comes to hands on mechanical it gets thin fast.. don't worry thou, that feeling diminishes with each accomplishment! Good luck, buddy. -arthr
/ Front wheel seals #4
Mace,
You might check in with Kendall ( PWGflyboy ). I think he just changed the front seals out on his 1510.
Bruce
/ Front wheel seals #5
Bruce
The 1500 and 1510 are completely different assuming they are 4wd.
/ Front wheel seals
John at RCO gave me the phone number of the mechanic to call. I am just worried that I could end up in a position where the tractor is not movable and not completable by me.
I have all of this week off so I'm about to dive in.......
/ Front wheel seals
Thanks again for the words of encouragement. Maybe I'll take my laptop out to the shop as I work and stay logged on. You guys make outstanding coaches.
/ Front wheel seals #8
If you've got a parts book to look at the assembly, a competent mechanic to consult, a reasonable assortment of metric sockets and wrenches and the other usual stuff, and are even moderately mechanically inclined it will simply be something new for you, not even close to "incompletable".
FWIW...until 10 years or so ago I was the anti-mechanic, the Darth Vader of shop work, a wrench's #1 enemy....I could screw up an oil change just by being in the room. And yet with all that going for me, I have done front seals & collars myself after watching it be done a couple of times.
Make sure you have all your parts. We will not consider replacing an axle seal without replacing the seal collar it rides on. Parts book will show you all these. You'll feel much more in control once you're done.
/ Front wheel seals
I don't have a parts book. Does anyone have a diagram they can post?
/ Front wheel seals
Getting ready to finally tackle the repair on Wednesday. I thought I'd post before and after pics.....
/ Front wheel seals #13
Mace,
Good Luck, you can do it. You might consider plenty of "during" photos too. They can come in handy during re-assembly.
Bruce
/ Front wheel seals #14
I would highly recommend you only repair one side at a time. You can then dissassemble the second side if you start questioning which way something goes back together. None of these parts are Yanmar specific. A good bearing store will be able to order them. You just need to take a good sample in for them to measure.
/ Front wheel seals
I completed both sides. It was a lot easier than I expected. I was a little supprised on the one side when I drove out the bolt tightening the pitman arm to the top of the hub and the whole hub dropped. Luckily no fingers or toes were in the way.
Have to run the tractor a while to see if it will leak or not......
/ Front wheel seals #16
told you...............;) You will now have much more confidence to deal with other repairs as the need arises.
/ Front wheel seals #17
Now that I have 30 or so hours on my tractor, I notice the front axle knuckle is starting to loosen up. I will need to go back and readjust my clearances. Keep an eye on yours less you break a gear from the misalignment.
2012 CTS BELLY DUMP (A67714)
2012 CTS BELLY...
HAMM 2210 SSD PADFOOT COMPACTOR (A67714)
HAMM 2210 SSD...
PORTA POTTY (A68842)
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
