Front Wheel Drive shaft BX2200
/ Front Wheel Drive shaft BX2200 #1
Skip G
Cheshire, Oregon
Kubota BX2200
Anyone ever hear of the bracket that holds the bearing for the front wheel drive shaft failing ?
/ Front Wheel Drive shaft BX2200 #2
That sound like a rather odd failing. Do you use 4 wheel drive a lot? How many hours on the meter?
/ Front Wheel Drive shaft BX2200 #3
Haven't heard of that one, till today...Did it possibly get hit?
Don
/ Front Wheel Drive shaft BX2200 #4
That does sound like an odd failure. I did have the roll pin that holds the frond drive shaft break, allowing the shaft to fall off the spline at that bracket. I guess it is possible that if the front axle was pulling hard when the shaft came off of the splines that it could put a good bit of force on that bracket.
/ Front Wheel Drive shaft BX2200 #5
I just saw your picture on your other post. WOW!!! Was there any rust in the breaks? Any chance you hit it on something solid? Looks like it is time for a new bracket, although I would look into having it welded.
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
BUNDLE OF UNION STRUT COVERS (A60432)
BUNDLE OF UNION...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
Hydraulic Concrete Breaker Excavator Attachment (A59228)
Hydraulic Concrete...
