Ballast Front weights.
  • Thread starter kingoflawns
  • Start date
/ Front weights. #1
K
kingoflawns
Guest
Does anyone know if Kubota has a front suitcase weight kit for a B7500? We are currently using the front loader for a counter weight when core aerating. We are looking to attach three to four hundred pounds. Thanks in advance. Scott
/ Front weights. #2
I have a B2710 with (3) suitcase weights on the front.
I think they weigh about 50# each.
I don't believe there is room for any more suitcase weights on the front, however I added some plate weights to the suitcase wts with a 1/2" dia x 12" bolt. There is a hole near the front of the suitcase weights that you can run a bolt through. I think that a 5/8" diameter bolt may work better than 1/2".
1/2" dia. is all I had at the time.
Hope this helps.
