front weights
   / front weights #1
tonyw
NC
YM1401d
I'm having no luck in finding a cheap set of front suitcase-type weights. Has anyone built their own?
I'm thinking of using a surplus ammo can(filling it with lead,concrete,etc.) and bolting it on. Any thoughts, suggestions, etc.?
Thanks!!
   / front weights #2
Tony,
If you do a search for "front weights", you'll find all kinds of suggestions and ideas. Just go to the Search function at the top of the page, click on it, and then type "Front Weights" in the area that says Words To Search For.
   / front weights #3
go to cusomization and look at the post titled brush guard that works.
   / front weights
Golfgar4,
Thanks! I should've given that a shot before posting my question! /w3tcompact/icons/blush.gif
Thanks to you too, Wichiwichi; I'll try your suggestion!
   / front weights #5
I got an old die section from a local factory and had it cut into 1 foot square sections at about 3" thick. Welded a chunk of angle iron on the top and hang them on the mounting plate of my snow blade. They weigh about 80 lbs. each. Works great.
   / front weights #6
Tony,
I added 151 lbs to the front of mine with surplus weights from an excersize machine, relatively cheap to purchase.
   / front weights #7
The weights added to the bracket
   / front weights #9
The bracket picture didn't post, here it is
   / front weights #10
I have to admit, mine doesn't look no where near as nice as those.
2011 GENIE GTH-5519 (A50854)
2011 GENIE...
More info coming soon! (A49346)
More info coming...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A51039)
2023 PJ 49FT...
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
