Ballast Front weights for JD4400 compact tractor
/ Front weights for JD4400 compact tractor #1
michaelbisset
Scotland
JD 4400 with 430 loader
I am wanting to get some front weights for my JD 4400 so I can run the flail mower without the need to keep the loader fitted as ballast.
The weight bracket was fitted already when I got the machine.
What weights do I need for this bracket and how many? The weights I think are R66949 at 42lbs each. Is that correct?
Happy for any advice or experience from members.
Thanks
MB
/ Front weights for JD4400 compact tractor #2
should be able to go right to jdparts.com and look up your model and it will tell you exactly which partnumber for anything on the machine. Very handy tool.
/ Front weights for JD4400 compact tractor #3
i have a set - it's been a while since i purchased them but i thought they were about 70 pounds each. i used them for a cab 4720. once you get them, invest in a small dolly so you can push them around and store them and push them right infront of your tractor for on and off ease. oh, they come with a metal rod that slides through once they are seated. you'll need a rubber mallet to tap the rod in and out.
/ Front weights for JD4400 compact tractor #4
I don't think the 70 pound weights will fit on the 4400. Not sure, but I got the 42 pound ones for my 4410. It will hold 6 of them.
