Ballast front weights again
/ front weights again #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Guys, I have a very steep driveway and use 3 concerte bags in my truck to help get traction when pulling out my boat. The are all hardened up by now of course, but they are darned heavy. Anyone ever tried a heavy nylon bag with concrete in it an just letting it drape over the front bumper? A few of these bags would add a lot of weight to the front of a tractor and cost very little. Trick would be to get a container strong enough.
/ front weights again #2
I remember a post on the old board where a guy made a mold and poured wet concrete in. It had bolts on a frame inside the mold. When it dried it was shaped like a rounded off car bumper. It could be bolted to the holes in the Yanmar bumper. I will attach the bumper / weight I made for my first YM1510. The 2" pipe was filled with molten lead. It was much heavier that it looks.
/ front weights again #4
Thanks, I took that picture and made it my logo for Kay's Supply. I put a lot of time into that one. The new owner says it is serving him well.
/ front weights again #5
kayssupply,
Here I go beating a dead horse again, but I "really" like the bumper you made for the 1510! /forums/images/graemlins/cool.gif Would you be wiiling to share your trade secrets on this one..like how you mounted it(bolt on or weld, etc.)? I've been collecting lead weights from tire shops and would like to make something similar for my 1401d.
thanks a lot!
/ front weights again #6
It was bolted on, using the factory holes in the bumper. I bent the 2" with a bender from Northern tool. I used fence post caps for the end caps. If I kept track of the time and had to bill for it, I probably had as much in the bumper as I did the tractor /forums/images/graemlins/grin.gif
I am in the process of helping a friend build a brush bumper for his Shibaura.
/ front weights again #7
thanks for your reply...
now what sort of pipe did you use...something like 2" electrical conduit? did you drill thru the pipe and insert bolts?
sorry for so many questions, but thank you for the help! /forums/images/graemlins/smile.gif
tony
/ front weights again #8
Here is my version of front weights for a 1401d. /forums/images/graemlins/grin.gif
Kinda rough for a bumper, though. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ front weights again #9
/forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif ha ha! I'm too poor for that kind of front end weight! somehow, my scoop ended up in the rear, so I really need weight in the front now!
thanks anyway jwjimbo
/ front weights again #10
My front weights are surplus weights of an exercise machine.
/ front weights again #12
It was made from 2" galvanized pipe. The center frame is made from angle iron cut to fit around the pipe. I put bolts through and welded the heads to the frame so you can set it up on the bumper and not fight the bolts. I had paint matched to the frame. I don't mind questions, it gets boring this time of year.
/ front weights again #13
thanks again..I doubt that my bumper will look quite that nice,
unless you're in the business of custom fabrication! /forums/images/graemlins/grin.gif
if you're taking orders, I need one to fit a 1401 /forums/images/graemlins/wink.gif
tony
/ front weights again #14
Inspector 507, that's another nice looking set-up.
thanks! /forums/images/graemlins/smile.gif
/ front weights again #15
</font><font color="blue" class="small">( I will attach the bumper / weight I made for my first YM1510. The 2" pipe was filled with molten lead. It was much heavier that it looks. )</font>
How much do you figure it actually weighs? Very nice!!
Bob
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A64280)
2024 BIG TEX 102"...
2016 Volvo XC60 SUV (A61574)
2016 Volvo XC60...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59912)
2023 UTILITY VS2RA...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
John Deere 7230 (A62180)
John Deere 7230...
