Front vs Rear Snowblower
   / Front vs Rear Snowblower #1
rbargeron
Elite Member
MA
L5450, L48, L3250, L345
I've used a rear-mount backup snowblower for a few years. Except for having to turn sideways in the seat, I like how the rear-mount works. I even made a drag blade setup for it last year.
This year an Erskine front-mount sorta fell in my lap so I've been using that one and trying to decide which is better. So far I can see each has its advantages. I think the backup style does a quicker and cleaner job on curved driveways. With the blower close to the rear wheels, it's easier to feed it around corners. Fewer passes are needed to complete the job.
The front go-forward style is definitely easier on the neck and is more convenient to control. On curved drives it seems to work better to cut a straight-ish path thru the middle first, then go back to clear the curves on each side. So it takes a bit longer. The front-mount is easier to sweep sideways in front of double-width garage doors, cutting down on the need for a drag blade.
So the jury is still out - maybe more people chiming in will be useful to others deciding which kind to get.
   / Front vs Rear Snowblower #2
Another big plus to my rear mount blower is that while snowblowing I can see directly in front of the blower so that I don't hit anything. With the front mount blowers, your sight distance is probably 3-5ft in front of the blower depending on the size. I have never used a front mount blower, but getting into tight areas with the rear mount is great. The steering is just like a forklift.
Also, how high can you lift the front mount blowers? I can lift my rear mount about 2ft or more off the ground. It makes it much easier to eat through snowbanks when you do the top half first and then the bottom. Just some food for thought...
Dmace said:
.......Also, how high can you lift the front mount blowers? I can lift my rear mount about 2ft or more off the ground. It makes it much easier to eat through snowbanks when you do the top half first and then the bottom. Just some food for thought...
All good points Derek - the Erskine lift is limited to 8" - 10" off the ground. If it is adjusted to lift more, it would not drop enough below level to follow crowns. Other front-mounts may have more range but the pto shaft may dictate the range anyway. My rear-mount blower's frame is adjusted short so the pto shaft is unhappy if it lifts too high - I can raise the whole blower about 16". The drag blade can drop about 8" below the cutting edge. (sorta like the Pronovost PXPL)
   / Front vs Rear Snowblower #4
I have a Kubuta B7800 with a rear 5 foot snow blower and I love it. I have the FEL on and between the two items nothings gets in my way! My neck takes a hit after a few hours of operation, but the effectiveness of having both the FEL and snow blower at the ready make for effective snow control - especially with the snow piles that my F250 with 8 foot plow builds up during the storm. I take the FEL and break up the piles after the storm is over and then back into the loose pile and get rid of it.
   / Front vs Rear Snowblower #5
I agree with above as well.
I had a frt mount rig and returned to rear mount but added a plow setup in place of my loader as I wanted some faster action for light snowfalls.
When snow is in the 4" range I do fast plowing to gather all the snow to one side of the drive and then blow that accumulation off to the boonies.
This results in two 'fast passes' and one slow blowing pass.
What many need to take into consideration is your tranmission type.
With clutch tractors you can well find that your drive speed is too fast for the blower to handle, hence rear blower may well be the only option as reverse is generally the slowest propulsion speed.
In my case both hi and low 1st in foreward are too fast for blowing any reasonable accumulation while in reverse I can handle anything.
Generally those who plan commercial snow blowing will order the tractor with a 'creeper' gear ratio.
Naturally hydrostatic transmission is the ultimate answer.
One important note; BE SURE THAT YOUR BLOWER IS AT LEAST 12" WIDER THAN YOUR WHEELS!
   / Front vs Rear Snowblower #6
I have always had a front mounted blower. My neighbor has a rear mounted one which he doesn't like much because he constantly has to turn his head to work. His tractor only has a rear PTO.
My thought would be if you have to snow blow a lot (we get 20 to 30 feet of snow, so I am out to blow every other day for several months), the front blower is much more comfortable on the neck, I would imagine. If you have some obstacles to manuever around, the front blower makes that easier to see how you are doing. I haven't really had a need for the FEL. I am surrounded by tall trees so we don't get drifting.
   / Front vs Rear Snowblower #7
To me this is one of the biggest cons to a front mount blower, you cannot see the obstacles you are heading for as well as a rear mount. With a front mount blower, you cannot see the first 3ft or more directly in front of the blower, whereas with a rear mount blower you can see directly in front of it. Also, it is much easier to manuever into tight areas.
   / Front vs Rear Snowblower #8
I wasn't thinking so much about things directly in front of the blower. I was thinking of things beside the blower such as steps that I am passing by, or walls. You are right, you can't see directly in front of the blower. I only do my driveway which I know quite well and haven't hit anything to break a sheer pin in probably 10 years.
In terms of manueverability, you probably are right. As I am having to look over my shoulder to see things, I am not so sure that the discomfort of the awkward position wouldn't offset, any visual advantage. I haven't ever used a rear mounted blower, so I can't be sure. But I know that I would never buy one in my current situation.
   / Front vs Rear Snowblower #9
I don't think anyone has mentioned that with a front blower you lose your front loader. I like having them both on the tractor at the same time most of the time. Now keep in mind that I only have a rear snow blower so I'll do anything and everything to defend it's superiority even if it isn't....
Now I need to go put a hot pad on my sore neck....
   / Front vs Rear Snowblower #10
Agree withe the hot pad! LOL!
I posted earlier on but what I neglected to add was that I had 'jury rigged' my 4' to work up front (quite well with an independant 16HP gas motor) and as another member mentioned, the forward vision is limited.
That 4 ft blower got trashed as I did not see a sizable metal object (gear box and one auger + auger shaft).
That is what led to the purchase of the 5' unit. which I promptly placed to the rear and added a plow blade up front.
Now I have the best of both worlds!
My loader bucket gets 'retired' in winter and replaced with the 6' push blade for the light snow falls.
Bucket to blade takes about 10 mins to convert as the loader arms remainin place. Simply the insertion of the 4 pins!
Next project:
To add a 'back blade' to my front plow for the 'close to the door work', but that's easy (when it gets warmer) last night was -28 deg cel.
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
2010 Toyota Corolla Sedan (A50324)
2010 Toyota...
7021 (A50322)
7021 (A50322)
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
