Tires Front Tires for YM2000
/ Front Tires for YM2000 #1
tpthibodaux
South Louisiana
Yanmar 2000
Does any one know the size of the front tires on a YM2000. I'm loking to buy some new front tires and I cannot read what size they are. Also does any body know where I can buy some cheap on the net?
Thanks Tim
/ Front Tires for YM2000 #2
Thanks Tim
4.00 - 15 I have the tires, but you should be able to buy them from a local dealer.
Danny
/ Front Tires for YM2000 #3
The 4 x 15 are correct. I did find some nice 5 x 15 5 rib implement tires for the front of mine. They are just a bit bigger and made a real nice front tire. Just make sure you have clearance if you go bigger. Plus they were cheaper. Found mine at Tractor Supply.
/ Front Tires for YM2000 #4
Just a thought..... I havent done it yet, but will look into putting truck tires on mine as soon as I get tired of the flats on the stock tractor tires.. A freind of mine added regular truck radial tires on his tractor years ago.. Didnt make much sense to me until I got my own and realized that the briars and thorn bushes are really hard on a tire.. The radials are more forgiving from what I'm told.. Anyone got a reason not to do this? I'm curious too, as I think it might be the way to go... At least another alternative, they could be used and not fit for the road because of plugs and such(IE - FREE)..
/ Front Tires for YM2000 #5
Its pricey but I had my tires sealed with MultiSeal, Have boisdarc's and honeylocust trees 3" thorns hard as a nail had so many flats lost count. Its pretty pricey think it cost around 400.
1  JACK (A66091)
1 JACK (A66091)
2009 ALLMAND  MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2023 Kubota KX057-5 Midi Excavator (A66734)
2023 Kubota...
AG Tires - 11.00-16SL (A68134)
AG Tires -...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
