Front tire questions
/ Front tire questions #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
Hi all,
There must be some experts on here. I have 20HP Yanmar, dry weight about 1500lbs+500lbs for the loader +the loader will pick up ~1000lbs max. I want to put turfs on the front, the rims that I have available are 14"x5" or 14"x6". The turfs I'm looking at are the diamond tread 6-14 (require 5" rim) and have a capacity of only 660lbs or 25-8.5x14 turfs which require a 7" rim, capacity ~1250lbs.
is 660 enough? can I put a tire that requires a 7" rim on a 6" rim safely, I know I can do it with a car tire, but was wondering about the load.
Please help?
Thanks,
Rob
Hi all,
Please help?
Thanks,
Rob
/ Front tire questions #3
Technically no. Theoretically yes.
/ Front tire questions #4
/ Front tire questions #5
won't two 660 lbs tires give you 1320lbs. I have seen 6x14 turfs on Fitestones site as well as titan's. If you are running a sxs you will also neede to change the rears to match.
/ Front tire questions #6
I've switched the rears already, I've measure the RCI to get matching fronts. While I agree that 660x2 gives 1320, I'm concerned about the odd situation that this might have a failure, on a hill, load in loader shifted,.....
4wd.
That is the reason I am looking for specific rims and tires for the front. I need to match the rolling circumference and front to rear ratio with my originial AG tires.
4wd.
JOHN DEERE CAT IV / III QUICK HITCH (A64278)
JOHN DEERE CAT IV...
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
2022 Honda Ridgeline AWD Crew Cab Pickup Truck (A64556)
2022 Honda...
UNUSED FUTURE D39 HYD TRENCHER (A65055)
UNUSED FUTURE D39...
CAROLINA 84" QT BUCKET (A64278)
CAROLINA 84" QT...
2025 IRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 IRanch IRTPL...
